How can I tap into the parking lights ?
Old May 31, 2006 | 08:38 AM
Mr. Francesco's Avatar
Default How can I tap into the parking lights ?
Where can i get to the wire with out tapping directly into the head lights?
I need to run an orange accessory wire, which sends a signal to a wireless remote to turn some fog lights on.
I only wan't to run it to the parking lights so that the fogs will only turn on when the headlights are on and not by accident so my battery dies.
Thanks
Old May 31, 2006 | 10:52 AM
xviper's Avatar
Old May 31, 2006 | 01:25 PM
thetz99's Avatar
A pic is worth a thousand posts
Old May 31, 2006 | 01:27 PM
Originally Posted by xviper,May 31 2006, 02:52 PM
where would you suggest i tap into? i value your opinion over most on this site
thank you for the picture also, im going to go take a look at the box now.
Old May 31, 2006 | 01:58 PM
PTHermes's Avatar
You could also tap into the red/black wire by the keyless entry module. It is located behind, and a little below the start button.
Old May 31, 2006 | 02:21 PM
xviper's Avatar
The thing that's labelled "lights". That's your power feed for the relay that will control your fog lights. Flip on the headlight switch to "park" or full on and your fog lights will operate.
Old May 31, 2006 | 03:18 PM
i understand that is where to tap into.
i was just curious to if you had a better suggestion or opinion
its ok though, ill do this.
Old May 31, 2006 | 03:38 PM
freq's Avatar
What are you up to Frank? I've always wanted to do the fog lights in the fake ducts on my AP1.
Old May 31, 2006 | 05:57 PM
xviper's Avatar
Anywhere you take power from, you still need it to be activated by the headlight switch. That one I put up is a ready made one. No point in hunting down a more complicated source. Make sure you use a relay.
Old May 31, 2006 | 06:48 PM
these fog lights have a relay box.
theirs:
2 positive wires : one for battery and one for fogs
2 negative wires: one for battery and one for fogs
1 orange wire: access. for the wireless remote
