How do you convert to mp3 format?
Old Feb 10, 2003 | 10:14 AM
dhallapex's Avatar
Default How do you convert to mp3 format?
What is the best way to convert a CD to mp3 format? Is there free software available? Can it be done using Windows Media Player?
Old Feb 10, 2003 | 11:10 AM
MacGyver's Avatar
There are a ton of freeware/shareware converters out there, with just about every imaginable level of quality. Be forewarned, however, that if the converter is free (legally so), the quality level is required by contract with Fraunhofer to be limited to (I believe) 96kb, or less.
Old Feb 10, 2003 | 11:34 AM
SeaDoXPL's Avatar
I use Musicmatch to "RIP" MP3s (Convert from CDs)
I like it because it will create a corresponding Album Folder and also name each song File With the Artistname_Albumname_Songnumber_Songname
ie:
Queens Of The Stone Age - Songs For The Deaf - 02 - Millionaire.mp3
Musicmatch allows you to rip only to 96KBPS with the free version.
Paying for the upgrade allows you to go all the way to 384KBPS if you wish. I try to stay around 128 KBPS to save Hard Disk space.
You can use Windows Mdeia Player to RIP but it will create WMA files.
They are supposedly equal in quality to MP3 and even have smaller file size. The down side is that not all players will recognize them.
I have had better luck with MP3s for sound quality and also the File naming doesnt work as well in Windows Media Player.
Music Match also lets you edit the ID3 Tag info within an MP3 File so that you can catolog them by Genre using any MP3 Player Organizer.
Old Feb 10, 2003 | 03:38 PM
MacGyver's Avatar
If you're encoding at 384 kbits, it's either in Layer I or Layer II, but not Layer III (where MP3 gets its name from...MPEG Audio Layer III). The maximum encoding rate for Layer III is 320 kbits. Layer III uses a more advanced psychoacoustic model than Layers I and II.
I have stayed far, far away from WMA-encoded files. Microsoft was QUITE clear in their intentions of making their music format the de facto standard over MP3, and they have proven time and time again how once they have become entrenched, royalty fees and unreasonable limits become a guarantee for the future. Expect to see AAC (or some new algorithms in the works) slowly take over the audio arena in the next few years...it's significantly more advanced and has a higher quality for an equivalent bitrate.
Old Feb 10, 2003 | 04:03 PM
SC_Highlander's Avatar
Exact Audio Copy is free and a very good encoder.
Old Feb 10, 2003 | 07:26 PM
bighead's Avatar
The new Windows Media Player 9 is awesome. It can rip in wither wma or mp3 formats, has an improved file labeling system (actually makes folders with album art as icons) Much improved over all previous versions. Need WinXP to use it though. Just my $0.02
Old Feb 10, 2003 | 09:41 PM
ASAP's Avatar
there is a freeware out there called CDex.
is a really really small program that lets you rip CD into MPEG-1 layer 3 from 32 to 320 kpbs, MPEG-2 layer 3 and so on...........
Old Feb 11, 2003 | 10:14 AM
TepEvan's Avatar
I use ACXtractor. You basically need to download the Blade.dll or one of the other dlls, but I rip at 192kbs since that's cd quality anyway. www.marvintec.com
Old Feb 12, 2003 | 08:10 AM
dhallapex's Avatar
Thanks for the info. It looks like there are a lot of choices so I'll just have to experiment. I just bought a new Dell with Windows XP and it came with musicmatch jukebox and windows media player (version 9 perhaps?). I tried to convert using musicmatch after i copied a CD to my hard drive, but it wouldn't / couldn't read the files. I copied them when I was listening to the CD with the windows media player. Perhaps they were copied as wma files versus wav files and that is the problem. It appears that the files must be wav files in order to encode to mp3 format using the musicmatch program.
Old Feb 12, 2003 | 09:00 AM
ASAP's Avatar
I don't know about musicmatch program. With others program you can just rip it off direct from the CD to mp3.
