How to hook up amp power to battery?
Old May 6, 2004 | 09:41 AM
Scanman's Avatar
Default How to hook up amp power to battery?
I'm installing a 2-channel 150W amp under the driver's seat. I need to bring the power directly from the battery. Do I need to just install a lug on the wire and connect it straight at the battery or is there a more convenient place I can tap the power from inside the car? Thanks for any advice.
Joe
Old May 6, 2004 | 12:37 PM
NFRs2000NYC's Avatar
Absolutely not. You have to wire amps directly to the battery.
Remove the battery.
Look at the firewall, youll see a rubber grommet with wires going into it.
Shove your power wire through....this will take work, but it will go through. Grease the wire with vaseline to make it easier.
After about 3 feet, youll see the wire inside the passenger side footwell.
Old May 6, 2004 | 12:48 PM
Scanman's Avatar
Thanks! I just need to run the positive right? Where's a good place to connect the ground wire from the amp under the driver's seat?
Old May 6, 2004 | 12:56 PM
if you stick your head under the dash under the drivers side, and look up, youll see a gold bolt with lots of little black wires coming out of it....thats a ground bolt. If your head is resting on the pedals, look at the door hinge area....its in that direction. Kind of by the fuse box area.
Old May 6, 2004 | 12:57 PM
See that gold bolt...thats the one!
Old May 6, 2004 | 04:32 PM
darkknight1999's Avatar
Good call Dave
Old May 6, 2004 | 04:35 PM
Originally posted by darkknight1999
Good call Dave
Gold Bolt means......
Old May 6, 2004 | 04:36 PM
Nice
Old May 6, 2004 | 06:04 PM
PJK3's Avatar
Old May 6, 2004 | 07:54 PM
Willie Gee's Avatar
bravo!
