How many watts Sub?
Old Aug 3, 2011 | 02:27 PM
Mikeysac's Avatar
Default How many watts Sub?
Wats up guys. I have an aftermarket HU and plan on adding a 10" sub and amp. How many watts are your subs? Just wondering because I dont want it to be overkill but I want it to hit. Lemme know! Thanks!
Old Aug 3, 2011 | 04:09 PM
DFWs2k's Avatar
Mines 2200 or 2400, i forgot
Old Aug 3, 2011 | 04:53 PM
vividracing.com's Avatar
Banned
What kind of music do you listen to? What kind of box do you want? What kind of bass are you after?
Peak wattage means very little, you should be looking at RMS wattage. Wattage in general is only a fraction of what makes a subwoofer sound a certain way or produce a certain amount of bass.
Old Aug 3, 2011 | 04:56 PM
Mikeysac's Avatar
I listen to predominantly hip hop with bass. I want a box for the hole in the trunk. I am after tight bass that wont rattle the trunk too bad. I am currently looking at something with like 300 watts. The rockford fosgate one.
Old Aug 5, 2011 | 01:39 PM
Mikeysac's Avatar
Anyone else have a sub in the tool well? How many watts (RMS) is it? Thanks
Old Aug 6, 2011 | 06:12 AM
lithoman's Avatar
This is what i have in my tool well. It hits....
Alpine SWS-1023D Type-S 10" subwoofer with dual 2-ohm voice coils
Size 10 -inch
Impedance 2 ohms
Cone Material Glass Fiber & Pulp/Kevlar
Surround Material Santoprene rubber
Ideal Sealed Box Volume (cubic feet) 1
Ideal Ported Box Volume (cubic feet) 1.2
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air No
Dual Voice Coil Yes
Sensitivity 84 dB at 1 watt
Frequency Response 30 - 700 Hz
RMS Power Range (Watts) 50-300
Peak Power Handling (Watts) 900
Top Mount Depth (inches) 4 1/4
Bottom Mount Depth (inches) N/A
Cutout Diameter or Length (inches) 8 7/8
Vas (liters) 30
Fs (Hz) 33
Qts 0.62
Xmax (millimeters) 12.9
Old Aug 7, 2011 | 04:40 PM
Mikeysac's Avatar
Yea yours is 300 Watts. I guess that is the right amount to get. Anyone else care to chime in? I really want to buy one soon. I have the funds just want to make sure I get the right one. Thanks!
Old Aug 8, 2011 | 02:28 PM
gumbey75's Avatar
500 watts RMS is what im running.
10 IN Alpine Type R wired to 2 OHMs, Should be plenty of power.
But you also have to make sure the amp you get matches the RMS rating.
Old Aug 8, 2011 | 03:54 PM
Mikeysac's Avatar
Hmm 500W. That sounds like a lot no? Your trunk doesn't like rattle or anything?
Old Aug 8, 2011 | 04:07 PM
gumbey75's Avatar
Perfect combo for me, It really depends on what kind of sound you really want to a achieve
