How much 5.25 rear speaker will improve sound?
How much more bass?(from searching I found out that 5.25 rear speakers dont add much bass at all..right??)
How much more midrage?
How more more high?
I mean is it worth more than investing $250?
Drametic improvement or just slight improvement?
I will be powering those with Aftermarket HU.
TIA
How more more high?
TIA
I think the best way to spend $250 would be to buy an amp for your speakers. As for the rear speakers, I just started playing with them tonight and decided that I'll definitely be going that route next! I just put the factory door speakers back there temporarily just to see what it would be like... pretty big difference!
That's my $.02
That's my $.02
I just (as in this weekend) added a pair of Lanzar 5.25's behind my seats and the difference is night and day. I can't believe how much better the sound is, especially at high speeds w/ the top down.
Before w/ just door speakers getting 60W apiece from an amp, I couldn't make out much of the stereo once I went above 60 MPH or so. After installing the rears w/ 60W to each of them I can hear the stereo "clearly" up until about 110 MPH
I can't say that rears add that much bass in my setup, but I have high-pass filters setup that cut off at around 80 hz. My 2 8's in the trunk get those frequencies.
I got the rears here :
http://store.yahoo.com/csexpo/vxlan525cars.html
Can't beat 'em for $30.
It was kinda hairy cutting the panels behind the seat because the fit was so tight, I literally had less than a millimeter of play.
Also, if you screw up, I found replacement panels for about $15 apiece here:
http://www.hondaautomotiveparts.com/auto/j...ry5=SIDE+LINING
it depends what you want out of the sound. i have a sony cdx-m850 headunit with polk compoents in the front. also i have 2 rockford subs pushin 500 watts in the trunk. i still need more SOUND the bass is fine but i need more SOUND, so i will be purchasing kenwood 3 ways rear + a multi channel amp to power the 4 speakers. again, its your car =D
sang
sang
instead of going the route of a rear speaker i upgraded my door speakers with a set of alpines and put a small amp on them and its more than loud enuf... complimented my 10" jl in the trunk really really well....
I originally added just rears and upgraded (not great but upgraded) door speakers with the 02 factory HU. This made a dramatic improvement and I was satisified with the improvement until now. The OEM HU with rears is sufficient at very low driving speeds with the top up. I finally got tired of the poor sound quality at highway speeds and top down that I'm upgrading all now.
