how to replace the control unit
Old Jan 24, 2008 | 07:51 AM
wanabe's Avatar
Default how to replace the control unit
took the car to the dealer to see why the keyless system and alarm are not working-
mine is an oem unit (option on my '00 when i got it new)-
they tested and said that the unit is bad.
ordered the unit and dealer wants my car all day for the install...
can not see why this is such a difficult install- but i need more info
cant tell in the service manual which unit it is that i have ordered-
page 22-128 shows a keyless door lock control unit... under the dash. i am thinking that the part that i ordered is the one under the seat, but i can not find it in the service manual.
anyone know how to do this install (remove the old one and replace it)?
Old Jan 24, 2008 | 01:20 PM
S2K2XGA's Avatar
Not exactly sure, but my OEM alarm is under the dash, drivers side. If it's the control unit it should just have one plug, maybe 2 2nd for the sensor and just replace the unit.. It's not like everything has to be rewired so there no way it would take all day. 15-30 minutes tops.
Old Jan 24, 2008 | 02:25 PM
HankookS2K's Avatar
1 hour tops. they do not have to do anymore wiring. just swap brains and reprogram.
Old Jan 24, 2008 | 02:30 PM
wanabe's Avatar
so its not the unit under the drivers seat for the '00 year??
how do i reprogram? (is that the push the button and turn on and off the ignition switch several times?)
Old Jan 24, 2008 | 04:26 PM
HankookS2K's Avatar
i believe so, i dont rememeber as its been a while since reprogramming the oem remotes. im mostly doing aftermarkets, but yea its sounds like you got the idea, i know it has to do with the ignition the remote button, and closing and shutting the door, (at least in the rsx it was). it should tell you in the owners manual or just give a stealership a call, they should tell ya.
or.....
http://www.handaaccessories.com/S2000/s2ksecurity.pdf
yea the alarm unit is under the seat. see according to that its a quick install if its just the unit going bad...should be a quick swap.... owners manual will tell you security operation, plus reprogramming i would assume
Old Jan 25, 2008 | 07:29 AM
wanabe's Avatar
great link- thanks hankooks2k!!
Old Jan 26, 2008 | 03:14 PM
wanabe's Avatar
picked up the part to do it myself and found out that it is the keyless control unit.... so not the unit that i thought, and not the one above-
the part number is 38380-s2a-a01
so it must be the one under the dash- will dig out the helms manual and see if that helps. looked under the dash and didnt see the unit, but guess it must be there!
Old Jan 26, 2008 | 03:53 PM
HankookS2K's Avatar
it is towards the start button under the dash iirc
Old Jan 26, 2008 | 08:31 PM
wanabe's Avatar
thx- will look again!
so it looks like i just unplug the old one and plug in the new one-
plug n play!!!
Old Feb 4, 2008 | 10:42 AM
wanabe's Avatar
dealer had me order a part that i didnt need...
they wanted my car all day for the fix, and i dont have all day for them to have my car!!
posted up in the so cal forum and was told that nsxnext1 could help. he came out, took out the drivers seat, unplugged the old unit to reset it, plugged it back in and all works again just like new !!
cant believe how dealers rip folks off...
and i want to give a shout out to art (nsxnext1)-
thanks art for fixing my car !!
