I feel dumb asking, but...
Old Feb 12, 2006 | 04:46 PM
Will's Avatar
Default I feel dumb asking, but...
Say you have a quality 4 channel amp, and it's 2 ohm stable and also bridgeable.
Say you hook up the front two channels to a set of components.
So, you have the two rear channels to play with and hook up to a sub. Which would be louder, or provide more power: bridging the rear channels, and connecting them to a single voice coil 4 ohm sub, or option #2...
bridging the two rear channels, and then connecting a dual voice coil sub, running it in parallel at 2 ohms? Is the 2nd option even safe/possible?
Thanks for any info.
p.s. having two subs are not an option i'd consider.
Old Feb 12, 2006 | 05:36 PM
darkknight1999's Avatar
It would depend on the amp and the sub.
Old Feb 12, 2006 | 06:15 PM
jwa4378's Avatar
Most 4-channel amps are not stable at 2-ohms (bridged). Even Alpine's MRV-F545 is not stable below 4-ohms.
If the amp is stable down to 2-ohms, chances are that it will produce more power than at 4-ohms. But that is only speculation. What is the model number / manufacturer of the amp in question?
Look it up online. There should be a rating for most wiring configurations and impediance loads. If it is a "quality" amp like to say, it should have an online manual of a reference guide of some sort.
John
Old Feb 13, 2006 | 07:46 PM
Will's Avatar
You are correct. I have yet to find an amp that claims to have a minimum safe bridged impedance below 4 ohms.
Old Feb 13, 2006 | 08:01 PM
Alphasonik offers quite a few... and umm well I'm an Alphasonik dealer cough...
Old Feb 14, 2006 | 06:18 AM
jwa4378's Avatar
dealer
John
Old Aug 2, 2006 | 04:03 PM
Turn-R-Us's Avatar
Good question. I am running a Alpine 4.150 PDX and running the fronts to the components and want to bridge the 3 + 4 channels to run my subwoofer which is an Infinity Perfect 10 DVQ. It is dual voice coil, I was planning to run it in parallel down to 2 ohms. Do you guys think that would be stable?????
Old Aug 2, 2006 | 04:18 PM
MDMAS2k's Avatar
YES, the pdx is stable at 2 ohm's.
I have the 1.1000 on a 12" type x sub and the 4.150 on the fronts with the second two channels open. I was running them on the sub bridged at 2 ohms but it was just not enough power for the sub. That is the only reason that I changed.
The amps are top of the line and the tech of tomorrow.
NFRs2000NYC's Avatar
It also depends on the sub. What kind of equipment do you have?
Old Aug 2, 2006 | 07:49 PM
Turn-R-Us's Avatar
I plan on bridging channel 3 and 4 on the Alpine PDX 4.150, so 300 watts at 2ohm to infinity perfect 10 inch VQ, 4 ohm with dual voice coil, will run them parallel down to 2 ohms.
