If I get a Alpine HU will the stock antenna work?
Old Oct 18, 2010 | 11:52 AM
AR-9's Avatar
Default If I get a Alpine HU will the stock antenna work?
I'm thinking if it doesn't there's a mod I saw someone on the forums do where both sides are symmetrical with no antenna hole. So do you think I would need it with a updated head unit?
Old Oct 18, 2010 | 12:01 PM
[DT]'s Avatar
Mine antennae wire just plugged right into the supplied connector on my Alpine IDA-X100. Sounds pretty decent though I don't listen to the radio much.
Old Oct 18, 2010 | 01:42 PM
Matt15's Avatar
it plugs right in. it's the fat round hole on the back of the HU
Old Oct 18, 2010 | 01:48 PM
s2k dre's Avatar
Old Oct 18, 2010 | 02:22 PM
ayau's Avatar
agree with everyone. however, your dash controls won't work with an aftermarket headunit. you'll need to purchase a modifry harness for that to work.
Old Oct 18, 2010 | 03:28 PM
Matt15's Avatar
and i can tell you first hand that it is worth it and works well
Old Oct 18, 2010 | 03:57 PM
energetic's Avatar
Moving to S2000 Electronics.
Old Oct 19, 2010 | 07:25 AM
Reckon's Avatar
My iDA-x303 works fine with the stock antenna. No issues.
Old Oct 19, 2010 | 12:49 PM
takeshi's Avatar
You'll actually want the DCI. If you just get the harness you'll be severely disappointed as the harness is just a bunch of wires and connectors. The Alpine PnP harness (highly recommended) is pictured below along with the DCI and an Alpine HU.
Old Oct 19, 2010 | 02:10 PM
iDashX's Avatar
And to answer your question.... yes your antenna will work. Just make sure you change your tuning mode when searching for stations (its the Play button)
