Installing MY04 Horn in a MY01
One of my few pet peeves about the S is the wimpy horn that has been installed on MY02 (maybe MY03 also) and sooner. Apparently, there was an improvement in MY04, so I bought a set of horns from the hardtop guy. I have searched the forums for some guidance on how to install the 04 horn on an 01. There have been some bits and pieces posted, but nothing definitive that I could find. I also have posted in "under the hood" with some luck, although no one seems to have first hand experience. At a friends suggestion, I will try posting in the electronics forum and see if I can get some help. Mind you that the MY02 and sooner have a single horn... MY03+ has two horns... and I believe the MY04 improved the sound of the double horn.
What I have learned thus far is that the MY04 is plug and play on 03+. Some have suggested that there is some wire-ing that nees to be run to do this mod on the 01??? Also, I have read that there may be some fuse issues and there are suggestions on increasing the amperage on the fuse so that the ABS and brake lights don't go out. I don't like the idea of just upping the aperage on the fuse however. Instead perhaps installing a relay on the line?
I have failed to come up with a good step by step on this mod. Mind you, this is not for Hella or Air horns... my query is for AEM parts here changing a 01 to an 04.
Unless I have missed a thread somewhere, perhaps this can be the first definitive one?
Thanks in advance for your help!
My experience is not related to an S2000 but i'm pretty sure the same applies. My 2005 Nissan Xterra came with a wimpy single horn. I bought a pair of horns from wolo-mfg.com and installed them. I did have to take the original wire leads that went to the stock horn and run them in parallel. I went from this:
to this:
I made no other wiring or fuse modifications, and everything works great. Hope this helps.
to this:
Thank everyone for your posts....
A friend RPSTL from the Gateway forum suggested this thread within the electronics community...
https://www.s2ki.com/forums/index.php?showt...=351212&hl=horn
Will thanks for your 2bits as well.
Other friends have suggested to replace the 15AMP with a 20 AMP and move on.
Sory to be a post....
on this subject.
I appeciate all the good input. If anyone has the magic silver bullet.... I will keep my eye out.
Thanks again everyone.
on this subject.I appeciate all the good input. If anyone has the magic silver bullet.... I will keep my eye out.
icex731
Nov 13, 2003 07:34 PM
