Ipod car connection
I can't speak for that exact combo, but many people have complained
about inadequate volume from MP3 players plugged in through an AUX IN -
in many cases the headunit is expecting a higher voltage signal than the
player produces.
see https://www.s2ki.com/forums/index.php?showtopic=580740
player produces.
Originally Posted by thepol911343,Apr 13 2008, 05:18 PM
the only disadvantage i see to this is that it wouldn't charge the ipod, but i guess you win some, you lose some.
The Belkin unit powers the iPod AND gives you a line-level output from the iPod dock connector which can then be used to input to a HU with an auxiliary input (such as an Alpine that can be used with the KCA-121B cable).
You will still need the RCA to mini jack adapter as the line-level output on the Belkin unit is a 3.5mm (mini) jack.
It is certainly not an elegant installation, but it is a way around Alpine's Full Speed connection for which you requested.
player produces.
player produces.
However, I have not had this issue when using the above mentioned Belkin unit as it:
1) uses the line-level output from the iPod through the iPod's dock connector, and
2) has a built-in amplifier to boost the signal.
But again, I only used this type of connection when iPod interfaces were not yet as readily available as they are now.
The Dension Ice>Link is an iPod interface for most head units that retains the iPod controls.
http://www.dension.com/icelinkplus.php
Originally Posted by thepol911343,Apr 14 2008, 06:54 PM
Thanks for clarifying 00civicSi. Did you happen to take any pics of this set up when you had it? Just wondering how "messy" all this would look installed?
Since my g/f would only use the iPod on longer rides, she'd just plug the Belkin unit into the factory outlet (I offered to install an additional outlet behind the dash for a more permanent install, but she didn't feel the need). There was only one black wire (mini-to RCA) that came out from under the console from the auxiliary interface (and was otherwise hidden beside the seat). Not messy at all.
Being that the S is already relatively cramped and the factory outlet is nowhere near the dash, I would not consider this arrangement (actually, I wouldn't because now there are iPod interfaces that work with the stock HU and plenty of aftermarket HUs with perfectly useful interfaces of their own).
I can't comment about cramming all of these components (KCA-121B, mini-to-RCA wire, additional accessory outlet, Belkin unit) behind the dash of the S, as I've yet to pull my HU. I'd imagine it'd be tight.
Ultimately, I agree with others that suggest just getting a HU with an interface that best meets your interests. Or better yet, just get a dedicated HDD that plugs into the USB interface on a lot of newer HUs.
