Lazer Shifter for Passport 8500
Old Feb 21, 2002 | 02:40 PM
mfabry's Avatar
Default Lazer Shifter for Passport 8500
Check out the new lazer shifting device that links to the Passport 8500.
http://www.escortradar.com/zr3.htm
Old Feb 21, 2002 | 05:26 PM
KeithD's Avatar
Saw that at Sound Advice.
Its a bit pricey, I would just go ahead and get the SR1 with it built in.
Old Feb 21, 2002 | 05:31 PM
BAD S2K's Avatar
The SR1 doesn't have this. The SRX does.
Old Feb 21, 2002 | 06:11 PM
KeithD's Avatar
Thanks. Sorry I meant the SRX.
Old Feb 21, 2002 | 06:19 PM
BAD S2K's Avatar
I've had the SRX for about 4 months now and it's great
Old Feb 22, 2002 | 10:55 AM
walkabt's Avatar
Bad S2K,
Where are sensors placed on your installation? I looked at the SRX at a local store, but they said they would mount the sensors in the grill area.
Old Feb 22, 2002 | 11:32 AM
BAD S2K's Avatar
I have 3 in the front grill and one on the rear plate
Old Feb 25, 2002 | 02:27 PM
modifry's Avatar
Honorary Member
I've been thinking about this one too. If I do anything it will definitely be a remote unit. I almost bought an SR1 till I found out the SRX was out.
If you don't mind my asking, how much did you pay for the SRX? Did you install it yourself or have it done? Where did you mount the display?
I'll definitely install mine myself, whatever I get. I've also thought about the possibility of concealing the rear IR "guts" inside the third brakelight housing. Cool idea but not an easy task, and would certainly void the warranty. But hey, I can't very well leave it "un-modifried" can I?
Old Feb 25, 2002 | 03:21 PM
BAD S2K's Avatar
$1500. The only way it is sold is installed. If your gonna cusyom install just make sure whatever you do doesn't interfer w/ the laser transceivers.
Old Feb 26, 2002 | 06:38 AM
mfabry's Avatar
Why don't yall get the Passport 8500 for $300.00 and the ZR3 for $500.00 (installed), which together in the same way that the SRX does for $700.00 less, compared to $1500.00 for the SRX alone?
