looking for stock radio harness...
I think this is what you are looking for...
https://www.s2ki.com/forums/showthread.php?...t=radio+harness
-Shing
-Shing
Originally posted by ceworkman
Metra harness number 70-1721. Should be available at any Hi-Fi Buys or Circuit City or any installation business.
Look at Macgyver's web page to find which wires you need to add to the 70-1721. You can pull a couple of "extra" wires from the harness, like rear speaker wires, and put them into the two remote control wires.
Private mail me if you need more specifics.
I would suggest that you pick the wires you "borrow" to adapt the harness very carefully. If you use the rear speaker wires then if you later decide to do a rear speaker install or get the one from Lucid then you won
ceworkman,
Thanks for the offer. I actually have quite a bit of experience in electronics...just not installing car audio. After hearing about having to cannibalize the connector anyway, I thought I may as well just put new pins into the stock harness. I just can't seem to find pins that fit that connector in the usual places.
[QUOTE]Originally posted by ceworkman
[B]I would suggest that you pick the wires you "borrow" to adapt the harness very carefully. If you use the rear speaker wires then if you later decide to do a rear speaker install or get the one from Lucid then you won
