Lucid, McGyver, etc, electronics types,,,,,, HELP!!!
Old Oct 28, 2003 | 03:33 PM
S2KGary's Avatar
Default Lucid, McGyver, etc, electronics types,,,,,, HELP!!!
I searched the library and all the "GREAT" info that used to be there is gone....
I hardwired my Val 1 a long time ago, this is how I know this info is available.
I need a constant on terminal off the fuse panel!!!!
I am hardwiring an XM Commander to my stock reciever and it needs both "acc" and "constant on".
Which terminal lug do I use for "constant on"?
My car is torn apart, and I don't want to put it together until I am done, my beer supply is running dangeruosly low.
Old Oct 28, 2003 | 03:38 PM
NFRs2000NYC's Avatar
I have XM as well. I did not use the fuse panel, but rather tapped into the power on the HU itself. The yellow wire is ACC and the red wire is battery lead. Hope this helps.
Old Oct 28, 2003 | 03:43 PM
S2KGary's Avatar
[QUOTE]Originally posted by NFRs2000NYC
I have XM as well.
Old Oct 28, 2003 | 06:10 PM
PJK3's Avatar
i'm going to look for a pic, but this should be easily searchable... until i find it, try giving the search a shot.
ok -- here's a thread for radar detectors...
http://forums.s2ki.com/forums/showthread.p...+radar+detector
Xviper has a post a couple down that shows exactly what you need.
Old Oct 28, 2003 | 08:24 PM
MacGyver's Avatar
Look at my first post in my windscreen thread...it lists which spade connector is which...
Old Oct 28, 2003 | 10:38 PM
S2KGary's Avatar
Thanks, that is exactly what I was looking for. However, I ran out of beer. Next time I will plan my modification "TOOLS" better.
Old Nov 7, 2003 | 07:59 AM
S2KGary's Avatar
Update!
Installed the XM Commander, for anyone interested, this is a sweet install. Now I have a small remote with a single wire running to the hidden xm reciever, which is hardwired to the cd changer slot on the back of my stock radio.
The kit came with a nice holder that will fit into the radio door, I just have to get the guts to cut the door.
BTW, the antennia that comes with this kit is super small I placed it on the trunk and it's size is almost unnoticeable.
Thanks MacGyver, your wiring diagram was exactly what I was looking for.
Fatbloke
Apr 13, 2011 01:22 PM
ximus
Apr 9, 2006 08:20 PM
Blurter
May 23, 2005 01:38 AM
S2KGary
Oct 28, 2003 05:01 PM
lostsol
Dec 1, 2002 01:37 PM
