Modifry Dash Bracket &.....
Old Jan 7, 2015 | 06:37 PM
Fastguy82's Avatar
Default Modifry Dash Bracket &.....
Hey guys, I'm a newbie. I've researched the topics on Modifry & Proclip as well as others. Like the idea of the placement of the Modifry bracket/on dash/out of the way. Pro clip USA has a new mount system. The IOauto Pro! A magnetic ball with adhesive to your phone, swivels in any position. http://www.proclipusa.com/targetsections/ioauto-universal-phone-holders.aspx<<< Anyone have a clue if it would be compatible with the Modifry bracket??
Old Jan 7, 2015 | 07:40 PM
Seanix's Avatar
Hey, why not get the modifry dash bracket with universal phone holder?
its actually a clean setup and doesnt interfere with anything else.
welcome to s2ki
Old Jan 8, 2015 | 07:00 AM
takeshi's Avatar
Looks like it uses a standard mount hole pattern. Odds are if it works with a ProClip vehicle mount it will work with the Modifry bracket.
There are a number of possible options that one can use. Preferences vary. The iOauto also looks like it is clean and wouldn't interfere.
Old Jan 9, 2015 | 11:39 AM
badboy00z's Avatar
welcome to s2ki
I had that setup but didn't like it. The bracket doesn't mount flush even with cutting the inside of the dash and the universal holder didn't hold the phone very well. My phone fell off on a few occasions.
Old Jan 9, 2015 | 12:06 PM
stupkid's Avatar
I had a modifry dash bracket and took it off and never touched it again after a day. It was too close to the shifter with the phone on. So I use a kenu airframe vent clip and it's way better.
Old Jan 10, 2015 | 01:50 PM
badboy00z's Avatar
I also use the Kenu Airframe and I really like it. Only downside is that if you have the heat on it heats up the phone but I just close the vent off.
Old Jan 13, 2015 | 12:18 PM
Trustd_1's Avatar
it's fine if you're not charging. w/the phone in the vertical position, the plug and cord are pretty close to the shifter.
Old Jan 13, 2015 | 12:51 PM
taifei's Avatar
I find that you have to trim the plastic at a pretty steep angle inwards to get the dash to fit a little more flush.
Old Jan 13, 2015 | 02:47 PM
stupkid's Avatar
My phone is always charging when it's on there vertically lol. Never gets in my way. I installed extra outlets around the car and have one behind the dash for charging. I run a wire from it to my phone and it works fine.
Old Jan 13, 2015 | 04:03 PM
carlmeister69's Avatar
How do you guys like the vent clips? I was thinking about buying to try it out but I was hesitant because I enjoy they AC.
