Music Cutting Out
Old Dec 2, 2010 | 10:56 AM
-=Zeqs=-'s Avatar
Default Music Cutting Out
Hello, I have had my current setup for almost a year now and up until a couple weeks ago, it had been running flawlessly. Lately though, I noticed that while I'm driving and even at a stop, the music will cut out, and then come back on after a second or so. This is regardless of whether it's the radio, or off of my iPod. I notice that my head unit stays on the entire time, so it doesn't appear that it has a loose power connection there. I haven't been able to confirm if it's the amp in the trunk, because when I'm parked in my garage after returning from a drive, it won't do it.
My setup is:
Kenwood KDC-BT742U 50x4 w/ front USB & Aux Connect
Kenwood KAC-7204 70x2 Amp
Infinity 6030CS Component Speakers
The amp is mounted in the trunk on the deck to the left of the spare-tool/recessed area.
Thanks in advance for any help guys.
Old Dec 5, 2010 | 07:39 PM
-=Zeqs=-'s Avatar
O_o nobody?
Old Dec 6, 2010 | 02:15 PM
ertbll's Avatar
Sounds like ur amp is cutting out. Mine uses to do that when it would over heat ill cut off the music but the hu is on. Check if ur amp is ok and not hot. I would look into the amp. Hope this helps
Old Dec 6, 2010 | 11:04 PM
iDashX's Avatar
sounds like amp is cutting out... possible short in your amp lead or grounding problems.
Old Dec 9, 2010 | 07:34 PM
-=Zeqs=-'s Avatar
I followed both of your advice. The amp isn't over heating. I checked the wiring and it appeared that the bold holding the ground wire had become loose just from driving over the past year. Tightened it back down and it works like a champ. Thanks for the help guys
Old Dec 9, 2010 | 07:49 PM
ertbll's Avatar
ohh glad we could help.!!!!!
Old Dec 9, 2010 | 10:59 PM
iDashX's Avatar
which bolt did u ground it to? and glad u fixed it... any more cutting ins and outs would fry it.
Old Dec 15, 2010 | 03:43 PM
-=Zeqs=-'s Avatar
You guys were wonderful, and once again, I appreciated it.
If you strip away the lining in the trunk, to the left of where the spare tire, there is a bolt that they used to secure the grounding wire when they installed my amp. I guess over the year of pot-holes and other road abnormalities, the bolt loosened a little.
At any rate, I'll be sure to check on that bolt from time to time now that I know that it's secured that way.
Old Dec 17, 2010 | 09:31 AM
ertbll's Avatar
ohh wow nice, you can put some thread lock on it just to secure it on.
Old Dec 21, 2010 | 06:11 AM
-=Zeqs=-'s Avatar
Never crossed my mind, but you're right. Some Loc-tite blue next time I go up to my parent's place and can use some tools with room to work.
Thanks again guys and Merry Christmas!
s2krazy01
Jun 8, 2012 02:32 PM
s2k_redhead
Jul 28, 2006 01:22 PM
jocko2
May 7, 2004 09:14 AM
J Nick
Jan 9, 2004 09:58 AM
Drunken_Monk
Oct 24, 2003 03:46 PM
