Need amp help
I am now running an Xplod deck and have a JBL sub that I need an amp to power, obviously. These are the sub specs:
12" Woofer PowerHandling - 120W RMS, 480W Peak, Impedance: 4Ohms What type of amp do I need? A Class D mono, 2 channel, etc...? |
Hey!
If you are planning to run the amp just for the sub you will need either a 2 channel or a mono block (1ch) amp. If you plan to run a pair of speakers aswell as the sub you will then need a 4 channel amp.. Either class A/D will be fine for the sub amp as you are running a lower wattage sub. Did you have any amps in mind? Hope this has helped you a little! |
| All times are GMT -8. The time now is 05:22 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
