Need amp help
Old Apr 16, 2005 | 11:44 AM
Xistence's Avatar
Default Need amp help
I am now running an Xplod deck and have a JBL sub that I need an amp to power, obviously. These are the sub specs:
12" Woofer
PowerHandling - 120W RMS, 480W Peak, Impedance: 4Ohms
What type of amp do I need? A Class D mono, 2 channel, etc...?
Old Apr 16, 2005 | 03:22 PM
dbzerk's Avatar
Hey!
If you are planning to run the amp just for the sub you will need either a 2 channel or a mono block (1ch) amp.
If you plan to run a pair of speakers aswell as the sub you will then need a 4 channel amp..
Either class A/D will be fine for the sub amp as you are running a lower wattage sub.
Did you have any amps in mind?
Hope this has helped you a little!
lude2S
Jul 4, 2005 02:51 PM
RadioSilence
Apr 7, 2005 06:08 AM
JP_BLACK
Feb 11, 2005 05:19 PM
CeleSaga83
Jun 20, 2004 08:58 PM
Ray
May 4, 2004 07:08 AM
