Need estimate on level of difficulty and time
Old May 11, 2008 | 10:40 AM
S2K Type R's Avatar
Default Need estimate on level of difficulty and time
Hi,
I bought the car with aftermarket head unit and now none of the stock radio controls to the left of the steering wheel function.
I would like to use one of those switches to trigger my garage remote as opposed to hiding it from theives. Is this a difficult and time consuming task? Anyone done something similar? any references to how-to's?
Thanks
Old May 11, 2008 | 07:37 PM
MikeyCB's Avatar
Would be pretty easy, actually.
All you would have to do is take a remote opener that you already have, then embed it under your dash, and splice the wires from one of the buttons in place of the original button on the remote.
I know that might sound non-specific, but things you will need are:
- Soldering iron (to make connections on the circuit board of the garage remote)
- Solder
- A length of wire (to splice the dash button into the remote)
- Possibly a wiring diagram of the dash if it's not completely visible without removal
- Electrical Tape
Old May 12, 2008 | 02:52 AM
ruexp67's Avatar
This might help:
http://www.modifry.com/freebies/old/garage/garage.htm
Old May 12, 2008 | 03:59 AM
JDR159's Avatar
Do what ruexp67 suggests, and also get Modify's DCI. Then you have best of both worlds: Radio buttons work again, and the garage door opener is hidden. I've done both and really like the setup.
Old May 12, 2008 | 05:12 AM
Will's Avatar
My garage door opener lives in a plastic bag by my headlight. High beam activation...
Old May 12, 2008 | 09:00 AM
S2K Type R's Avatar
Thanks for the suggestions everyone. Will try out some ideas in the weeks to come!
Old May 12, 2008 | 06:43 PM
RedY2KS2k's Avatar
Pardon my ignorance, but how does that work as you turn the high beams on/off as you drive down the road at night?
Old May 12, 2008 | 06:50 PM
ruexp67's Avatar
As long as he is out of range of his own garage door, nothing happens. Sure it's sending out a signal, but so what?
Old May 12, 2008 | 07:32 PM
Will's Avatar
Yep. It's the "intellicode" opener so it's supposed to not be able to open anybody's door but mine. No problems so far, i've had it wired in for a couple years now.
Old May 18, 2008 | 08:02 PM
DryCycle's Avatar
I stuck some velcro on the opener, and put the entire opener on the "inside" of the dash on the left side just inside the bottom edge of the dash panel. I just reach under there and push the button.
