Need help
Old Mar 14, 2007 | 02:37 PM
DFWs2k's Avatar
Default Need help
I have enough money set aside now to go with my next electronics mod.
I have it narrowed down between 2 choices,
Choice #1
A Mayhem 900 series alphasonik sub that should be able to handle my amp in a custom fiberglass box, which will allow me to use my trunk again. Box and sub will be handled by DarkKnight1999.
Choice #2
The new JVC h/u with dvd/navigation and the molded screen, also would be ordered from DarkKnight1999.
I am having trouble deciding between the 2 choices because I would like navigation, but I would also like to use my trunk. I think Choice #2 would look cooler, but I also need to weigh the options between getting pulled over, because I can't get pulled over anymore, as it would result in a terrible situation.
So with that additional information, which would you go with? Choice #1 or Choice #2?
The other choice will be done at some point in the future as well, probably summer time. And I know that Choice #2 is going to be more expensive, I just can't afford both right now.
Thanks for the input!
Old Mar 14, 2007 | 08:54 PM
darkknight1999's Avatar
I spoke to the JVC rep tonight and he honestly wasn't sure if the HU will output the navi info to a secondary screen.
I did however really like the JVC KD-NX5000 what a great looking unit with so many features!
I'm thinking about getting it myself
Old Mar 14, 2007 | 09:03 PM
InsaneInNC's Avatar
IMHO, the choice is easy based upon what you said. Go with #1. You will get your trunk back, and you won't have to worry about being pulled over (at least due to not having a rear view mirror if it is the setup I think you are referring to). Sometimes practicality outweighs coolness.
FWIW, I have a Garmin StreetPilot 2610 that I have been using for years, and just bought a new mount that uses a suction cup to the window (Click this link to see mount at Amazon.com). I really love the ability to take my one GPS unit and use it in either of my cars. Furthermore, I am going to be purchasing one of William Laurent's subs this weekend, just so I don't loose any valuable trunk space, either; unfortunately, I have been procrastinating getting this sub for way too long (all due to my own financial priorities).
Just my $0.02.
Good luck with your choice.
Old Mar 14, 2007 | 09:12 PM
You do not "need" to have a rearview mirror by law When was the last time you saw an 18 wheeler with one? Or an RV, or a Uhaul for that matter... its fine.
I've never had anyone question me with it. I've been pulled over and they never even mentioned it to me.
Old Mar 15, 2007 | 07:15 AM
DFWs2k's Avatar
Seems like I'll be going with the sub for now until I can get some more information or until someone has the NX5000 outputting to a secondary screen, as I don't want to have to squint to see the directions.
John, are your PMs working again yet?
Old Mar 15, 2007 | 09:32 AM
InsaneInNC's Avatar
Darknight:
Be careful what you say, and how you say it.... In this case, you are partially correct, but your intent/conclusion is wrong. In the state of NC, for example, you MUST have a rear view mirror INSIDE a CAR:
[QUOTE=NC DOT Safety Inspection Version 1.12 - August 2006]
Section 19A NCAC 03D .0540 MIRRORS:
1. Mirrors shall not be approved if:
(a) Loosely mounted.
(b) Forward vision of the device is obstructed by mirror assembly.
Old Mar 15, 2007 | 08:45 PM
Do you really think I'm going to read that... thanks for showing the kind of person you are. Do you really think I'm going to read that? I mean really... do you have absolutely nothing else to do but run around and try and find fault with things people say?
Ok fine are you happy now... Do you feel better inside?
Its a rear view camera, its works better than the mirror in pretty much every way. I'm not removing the ability to see behind the car. I'm just using a different way to see... and see better I might add.
But as it also turns out I didn't run around and check every state law... and I don't plan to either... but you can feel free to. Have fun
Old Mar 15, 2007 | 08:51 PM
BTW someone in NC needs to be told its 2007... and its ok to have and use technology....
Old Mar 16, 2007 | 07:23 PM
InsaneInNC's Avatar
Darknight,
Don't be too defensive. What you said was incorrect. Accept that. From your experience, YOU have not had an issue with your local laws. All I was pointing out was that different states have different laws. YOU cannot say with any certainty that where DFW is located, or anyone else for that matter, that he would or would not "need a rearview mirror by law." Neither can I. What you should be telling people, if you get off your high horse, is to check with their local inspection stations or state DMVs for clarification. They may be able to use your setup legally; maybe they won't. That is all I am trying to say.
Old Mar 16, 2007 | 07:33 PM
InsaneInNC's Avatar
Very mature. I would have expected a lot more from one of the most respected people on this site. I guess when you are told something you don't like, like the people you bash, you turn to be a whiny brat. :-(
