Need Help for adjust amp frequency
Old Jun 1, 2002 | 11:08 PM
jays2000's Avatar
Default Need Help for adjust amp frequency
Hi I have Pricision power amp and it has a frequency adjust and it show that can adjust from 30hZ to 4khz. can anyone help to explain what it is and what position should i adjust it to. tahnk you
Old Jun 2, 2002 | 04:43 AM
MacGyver's Avatar
The frequency points suggest a high-pass crossover point adjust, not a subsonic filter. Subsonic filters are designed to remove the REALLY low frequencies that human ears typically can't hear (hence the term 'subsonic'). While SOME amps can faithfully reproduce these frequencies, they are generally matched up with a specifically designed speaker as well....I'm talking stuff in the 5-15 Hz range, and the speaker is specifically designed to move the diaphragm slowly, but powerfully.
Old Jun 2, 2002 | 04:46 AM
MacGyver's Avatar
Oops, sorry, forgot to suggest where to set it. This will depend on your particular setup, of course. If the amp is driving full-range speakers, set it as low as it will go, or turn it off, if possible. If it's running subs and you can't turn this off, you're using the wrong amp. If it's running full-range and/or mid-range and/or tweeters, AND you have another amp running subs, you should set the crossover point to a frequency just below the cut-off point of what your subs faithfully reproduce.
Old Jun 2, 2002 | 05:20 AM
matrix's Avatar
Jays2000
Can you give us more information about your system? We need more information before we can really comment.
Do you have a sub?
Is this amp running the sub?
Is this your only amp?
Old Jun 2, 2002 | 10:06 AM
jays2000's Avatar
thank you for all the respond. this amp is usinf for four component speaker . this amp is four channel. also i use the other amp which is two channel to use for two 10 inch sub. this is my system look like please advise thank you
Old Jun 2, 2002 | 10:59 AM
MacGyver's Avatar
OK, we can be more specific now. Determine what frequency range your subs are good to...let's say, as an example, your subs reproduce good bass up to around 300 Hz. On the amp that's running your separates, turn the high-pass crossover point to something just below that, say 250-280 Hz. This way, the subs produce the heavy hitting notes, and the separates pick up where the sub starts to leave off without attempting to do what they're not that good at (reproducing bass notes).
Old Jun 2, 2002 | 02:44 PM
rstark's Avatar
[QUOTE]Originally posted by MacGyver
[B]The frequency points suggest a high-pass crossover point adjust, not a subsonic filter.
Old Jun 2, 2002 | 09:38 PM
jzr's Avatar
jzr
[B]OK, we can be more specific now.
Old Jun 2, 2002 | 11:42 PM
jays2000's Avatar
So for four channel (component speaker) should set to high pass at 120hz and two channel (sub) low pass for 120hz right
Old Jun 2, 2002 | 11:55 PM
jzr's Avatar
jzr
Yes, exactly!
