Need help with adjusting JL 500/1 Amp
hey, i just hooked up my 10w6v2 to a jl 500.1, but the installer turned it up pretty high and now the sub is overpowering my mids/highs. What should I do to lower the the amp output? There are so many knobs in teh back of the amp.
This sub hits so damn hard that I can't even turn the volume up 1/3 the gain. But at that volume, I can barely hear my speakers.
Here are teh adjustable knobs
center frequency
infra frequency
boost control
"Q" ???
filter frequency
which one is to control the amount of power going to the sub??
Boost???
center frequency
infra frequency
boost control
"Q" ???
filter frequency
Boost???
Originally Posted by Grimey,Jul 19 2007, 04:47 PM
You will want to adjust the gain, or input sens. knob. If you turn that down then you can level out your speakers and sub woofer levels.
Originally Posted by yungjoc,Jul 19 2007, 09:11 PM
I will look for a knob that says gain or input sens. I believe there is one that says 0, +4, +6, +8...etc..
Originally Posted by Cubs2k,Jul 19 2007, 05:30 PM
Although that is one solution....you should describe your full system and settings (ie.crossovers). You could actually have too low a gain setting on your mid/highs.
I'm runnning
phoenix gold rsd 6.5 components pushed by a jl e2150 70watts per channel
pioneer 880prs headunit
jl 10w6v2 pushed by a jl audio 500/1
Originally Posted by Grimey,Jul 19 2007, 05:55 PM
I didn't know that you had an amp on your mids and highs too. What I would do would be to put your mids and highs amp at about 5/8 of the way up on he input sens. then adjust your sub amp to level out the sound. The reason you want to put you amp at about 5/8 is because you don't want to overwork you amp to produce distortion or heat.
Originally Posted by TrackStar,Jul 20 2007, 06:09 AM
Also there is a switch that says input voltage high or low. Setting it to high will reduce it quite a bit.
