Need Help Deciphering Alpine
Old Jan 13, 2004 | 03:01 PM
Chadwick's Avatar
Default Need Help Deciphering Alpine
i need some help. i have the Alpine brochure. i'm confused. i want a good HU (9815), and i also want to install a screen in the dash for a navigation / dvd system. aside from amp / speakers, what do i need to get everything up and running?
normally id know, but in t e s2000 there isn't a lot of extra room.
also, is a 5.1 setup possible?
Old Jan 13, 2004 | 03:52 PM
NFRs2000NYC's Avatar
Please dont take any of this offensively....this is just for helping you out.
First of all, since you are asking a question like that, you obviously are not very well informed on car audio. In which case, if you want what you are looking for, you are talking about A LOT of custom work, which means a lot of money. I suggest you look at your budget, understand what you are trying to do, and then work from there.....in which case I will be glad to help you. Good luck!
Old Jan 13, 2004 | 03:58 PM
Chadwick's Avatar
Yeah, I guess I was pretty vague.
Basically, I want my end result to be a competition level (SQ Comp), with the navi system.
I've actually done a setup before in a different car similar to this, but I used different branded material, but this time around I really like Alpine's offerings.
I'm not sure how logical a 5.1 setup would be in such a small car, especially being a convertible, so I am probably going to dump that idea.
Basically all I need to know really is can I use the 9815 as the center of my setup. Meaning can it, along w/ a screen and navi setup, control all the functions that I require of it? And would it be a good HU for a SQ comp, or should I not even consider Alpine as a brand in this venture?
Old Jan 13, 2004 | 04:19 PM
Alpine is perfectly fine for SQ. If you want to really have some big SQ...you can get the digital sound processor....but I think that waaaaay overkill in an s2000.
5.1 is easy if you are already tearing your dash up to stick in a screen, then you can just have them cut some more for a center channel, and get rear speakers, and BAM, 5.1!
Old Jan 13, 2004 | 04:23 PM
Chadwick's Avatar
[QUOTE]Originally posted by NFRs2000NYC
Chadwick's Avatar
Oh, and thanks for the replies
Old Jan 13, 2004 | 04:27 PM
No problem....yes for 5.1 you need a digital processor, also available from Alpine. I think, although Ive never actually heard it, that 5.1 in an s2000 will sound good....IF done right.
Old Jan 13, 2004 | 04:30 PM
Chadwick's Avatar
Another question on the rear channels. Wouldn't the S-Pods kill the sound stage? However, I like the cleanliness of the S-Pods. What other alternatives do I have?
Old Jan 13, 2004 | 04:35 PM
You can use the lucid rear panels....available from lucidautomotive.com
Old Jan 13, 2004 | 04:39 PM
Chadwick's Avatar
Awesome, all I needed to know. Thanks a lot!
