NEED HELP WITH INSTALLATION
Old Jun 1, 2006 | 11:23 AM
BeerFork's Avatar
Default NEED HELP WITH INSTALLATION
Hey everyone,
I'm installing an ALPINE 9857 and Modrify DCI as we speak. Except the problem is, i can't get the bloody brackets off the factory head unit. I tried with a regular philips screw and a drill bit, but it ain't moving. Plus it's starting to shred the screw. Is there a trick to this? Am i suppose to hop on one leg while rubbing my belly before i start? Would it be ok to drive withou a radio? Cause i gotta work soon. Thanks in advance.
William
Old Jun 1, 2006 | 02:13 PM
unscathed's Avatar
Honda really tightened the hell out of those screws... no trick really... just apply plenty of downward pressure while "lefty loosey-ing."
Good luck.
If you do strip the screw, dremel it a new head.
Old Jun 1, 2006 | 02:59 PM
Avernus's Avatar
No it wont be alright to drive without the radio. You may suffer a Music deficiency Also known as Arthrogrypodic-maxilinodemia. Bad stuff to say the least.
Old Jun 1, 2006 | 03:45 PM
hpark's Avatar
yeah that was pretty tough to get off.....i just used a philips screwdriver and applied as much torque i could for a few seconds and it snapped off.
Old Jun 1, 2006 | 09:08 PM
TwinC's Avatar
Helps if you use the right size philips... you probably are, but just thought I'd mention it. Do it by hand, unless you've got the radio in a vice and can apply downward pressure on the screw... otherwise, the drill will strip the screw... especially with the typical #2 bit...
Old Jun 2, 2006 | 10:34 AM
NO RIDE's Avatar
you can always buy new brackets. i believe they are 3.50 a piece.
Old Jun 2, 2006 | 11:15 AM
Cyclon36's Avatar
Yeah, I've seen a lot of screws on those brackets that are too tight. I stripped on by accident. I ended up getting it off with a pair of pliers. Just squeezed the screw on both sides. It's pretty beefy so it's easy to grab. I imagine a set of channel locks would work well. With the pliers, they came off real easy.
Old Jun 2, 2006 | 04:14 PM
SheDrivesIt's Avatar
I think one of the problems here is that they are not phillips head screws. The japanese "plus heads" as they call them have a different taper. Our phillips head screw drivers have a hard time gripping them. I work for a Japanese machine tool company and we all buy JIS style screwdrivers.
Old Jun 2, 2006 | 07:45 PM
globallyoff's Avatar
I just manned up on mine tonite and put as much pressure forward as I did twisting. Those bad boys broke loose fairly quickly......LOL
Old Jun 2, 2006 | 08:03 PM
BeerFork's Avatar
Well i got three out of four off, still working on the fourth one. Where can i buy it? Honda dealership? Stereo place? Circuit City? Do tell!!! Because i can't even tell the last screw is a philips or plus head anymore.
