NEED HELP ON MY DCI!
I just got my DCI today and hooked it up following every direction. I have a alpine ida x001 and got the wired DCI for it. I check and recheck the directions and connections. My controls are not working... =( I need help bad can someone tell me what i am doing wrong? or what i should do. THanks
-Is this model supported? It should be, but check to make sure.
-Are there two 3.5mm jacks on the back of the headunit? One will be aux input, and one for the wired remote.
-Check for voltage on all the power pins.
-Also check the dash control wire (green/red) changes resistance between buttons in reference to ground.
Originally Posted by DFWs2k,May 4 2009, 12:51 PM
don't you have to have one of those flip switch things? did you get modifry or a different one?
There is a 3.5 mm jack on the back of the HU. but dont know what to do with it?
How do i check the voltage on the power pin?.. everything work fine when i turn it on.
Aight i will check the green/ red wire.
you may have seen these already, but here are Modifry's troubleshooting pages:
DCI Help
DCI tech page
DCI Help
DCI tech page
DCI Help
DCI tech page
DCI Help
DCI tech page
noting looks out of place in your pictures - I assume that's Modifry's
Plug&Play harness, so hooking it up should be pretty foolproof.
try pulling apart all the connectors and making sure there are no
bent pins, if you haven't already.
