Need help with Radio
Old Apr 9, 2009 | 09:10 PM
junchoi206's Avatar
Default Need help with Radio
yea~ it is about the radio code but it is quite different
i did got the radio code from honda but i guess i wrote it down wrong
so i got a correct one now but the radio won't turn on -_-;;
i even took out battery cable for few min and put it back but it still
won't work... please help~~
i need music to drive!!!!
Old Apr 9, 2009 | 11:30 PM
Claus's Avatar
If the radio is the original one that came with the car, then you find the code for free from Honda Owner Link
https://www.ahm-ownerlink.com/login.asp?brand=honda
Give it a try again?
Old Apr 10, 2009 | 01:20 AM
junchoi206's Avatar
i did get the code but the radio won't turn on (by meaning can't even type in the code)
also i did took out battery cable again to reset it..
Old Apr 10, 2009 | 07:23 AM
Brianm0121's Avatar
I have the same exact problem, the radio still has power to eject the CD that was in it but that's it. It won't turn on to display "CODE" or whatever the message is.
Old Apr 10, 2009 | 09:29 AM
junchoi206's Avatar
yea same for mine T.T we really need help~!!~
and i did switch the battery
Old Apr 14, 2009 | 04:37 PM
gumbey75's Avatar
check your fuses? if so the deck maybe have locked out on you.
Old Apr 14, 2009 | 07:45 PM
junchoi206's Avatar
which fuse should i check?! i do lost my manual... T.T
and is that the fuses in my engine room?! or is it some where else?
Old Apr 17, 2009 | 06:21 PM
Friday's Avatar
can yours eject the CD?
if it can i don't think it's the fuses problem.
Old Apr 17, 2009 | 07:05 PM
Utah S2K's Avatar
If your battery goes dead or is dosconnected, or the radio fuse (no.19), then a stock head unit will go into safe mode and disable itself. If this happens you will see the word "Code" in the frequency display the next time power is restored to the head unit. If this happens you need to use the preset buttons to re-enter the code. If it is entered correctly it will start palying again. You have ten tries to enter the correct code.
Important Note: If you make a mistake or enter the code incorrectly DO NOT START OVER. Complete the five digit sequence, then enter the correct code. failure do do this will make it so the partial entry is carried over (i.e. you are not entering the code you think you are). If you are not successful in ten attempts all is not lost. You must leave the system on for 1 hour before trying again.
Fuse: Number 19 is located in the under the dash fuse block around the drivers side where your left knee would be. Its a 15 Amp. It's in the right row (there are two rows of fuses, right and left. It's either the 7th from the top or 7th from the bottom. I can't remember. I do remember the owners manual says from the top and the Helm manual says 7th from the bottom...but I can't remember which manual was right
Utah
sgt
Aug 16, 2018 03:10 AM
bp1952
Apr 26, 2012 10:38 PM
donnatronious
Jun 3, 2008 08:43 AM
Jalin-O
South Florida
Apr 24, 2007 10:05 PM
