Need some help project
Old Feb 18, 2004 | 04:14 PM
ludeboye's Avatar
Banned
Im doing a project where i have to make the bulb blink at number 3 you guys think im doing this right? Because i tried it with a 6v power supply and the number 3 bulb did not blink can someone help me
Old Feb 19, 2004 | 06:41 PM
jankemi's Avatar
Nope. The relay is just a switch, not a power source, so you do not have any power feeding the bulb.
Old Feb 19, 2004 | 07:25 PM
ludeboye's Avatar
Banned
[QUOTE]Originally posted by jankemi
Old Feb 19, 2004 | 07:42 PM
MacGyver's Avatar
Component 4 seems to be missing a pin/wire, but I'm assuming you left it out for clarity. Other than that, the circuit DESIGN looks fine. However, if you're using a 6V supply with a circuit that includes 12V components (particularly relays), you can easily run into trouble. Relays need a certain amount of pull on their coils to pull in the reed switch, and 6V is probably not enough to accomplish that task...if it is rated for 12V, use 12V.
Old Feb 20, 2004 | 03:36 AM
jankemi's Avatar
Maybe I'm missing something - How does the bulb get voltage if it is on the secondary side of the relay and there is no voltage source for that side of the circuit? All I see is a bulb & the relay in the circuit. Does the voltage to light the bulb somehow leak through the air inside the relay?
Old Feb 20, 2004 | 07:46 AM
MacGyver's Avatar
My bad, I wasn't looking at the top portion, just the switching portion.
The currently designed circuit will switch correctly, but will never apply power any source of power to the lightbulb.
Old Feb 20, 2004 | 05:01 PM
jankemi's Avatar
I figured that, as I'm sure your knowledge of electronics is at least two orders of magnitude beyond mine.
siadam
Aug 24, 2011 11:20 AM
ximus
Apr 9, 2006 08:20 PM
stocks2k
Jul 26, 2004 11:23 AM
s2k_9000rpm
Jan 6, 2004 05:25 AM
Kibro
Sep 16, 2001 11:47 AM
