No Bass respone as i predict before
Old Jun 19, 2002 | 03:02 PM
jays2000's Avatar
I just install the two componet speaker and two rear componet speaker and two tep inch subwoofer and i don't know why i can't feel the bass from the sub i feel only from my component. I have enough of power to run those speaker. or my amp panal close the space for sub to kick need advise.
Old Jun 19, 2002 | 03:18 PM
lucid's Avatar
need more info and specs on your system.
Old Jun 19, 2002 | 03:41 PM
jays2000's Avatar
I have FRONT=MB QUART QM 218.61Q REAR=MB QUART PSD213 i use PPI 440 to power those speaker SUB=two 10 inch S10L7 i use PPI 2200 for those two sub. i have a 1.0 cap. I need advise why i can feel the bass only from copmponet speaker. should i build the sub box.
Old Jun 19, 2002 | 05:22 PM
lucid's Avatar
1. check your wiring - RCAs, speaker wires etc. polarity correct?
2. Did you wire your dual subs in series or parallel? 2 ohm or 4 for the speaker?
3. adjust your input sensitivity.
I think the sub amp u have is an AB class stable to 2 ohms (not 100% on the specs). If they are the 2 ohm verion you may be wiring too much load per channel. Since its DVC its most likely the way its wired. If it IS only stable to 2 ohm keep each sub at that.
Bass
Aug 6, 2018 11:10 PM
S2Kmonkee
Jan 25, 2010 03:17 PM
06fg2ftw
Mar 24, 2009 10:51 AM
black s2k
Dec 27, 2005 06:59 AM
r_duff
Nov 16, 2004 05:14 PM
