OBDII - wifi vs bluetooth
Old Jul 4, 2016 | 07:15 AM
lovegroova's Avatar
I connect the bluetooth on my Androids (Galaxy S2 and now Sony Z3 Compact) to both my OBD2 and 10Hz GPS at the same time.
An el cheapo OBD2 worked perfectly, something similar to this: https://www.amazon.c...uetooth+adapter
I have upgraded to an LX as linked above. It has one or two nice things, but is no faster at refreshing as the AP1 refresh rate is limited by the car (to about 1Hz). If you have an AP2, then it's probably worth spending the extra.
App used to monitor things is Torque Pro: https://play.google....rg.prowl.torque
So I expect you'd be fine linking to a head unit and OBD2 at the same time.
Here's what I use it for:
[media]http://www.youtube.com/watch?v=ubNrDSV4tBY&hd=1[/media]
Old Jul 19, 2016 | 12:07 PM
Krazykoreankid's Avatar
Originally Posted by 99SH
Bluetooth is the way to go. This piece is very reliable: http://www.obdlink.com/lxbt/
What Sensors are you planning to monitor while driving? I can't see anyone turning on their phone 100% of the time to display gauges.
bought your recommendation of the OBD-II (bluetooth) very good piece of equipment. Easy to install and easy to modify the gauge displays. A little more expensive than the others but it comes with its own dedicated app that gives you a bunch of custom input options that others would have to pay to unlock in other apps.
Thanks!
Old Aug 2, 2016 | 08:39 AM
so far I'm pretty darn happy with the capabilities and ease of use for my OBD-II scanner.
ran into a problem with dashboard gauge readouts, but turned out to be user error.
here's a link to my little problem (and solution) and the forum for the device in case you've bought one yourself and have a few questions.
https://www.scantool.net/forum/index.php?topic=13015.0
Old Aug 2, 2016 | 08:44 AM
VERY COOL! what mount do you use to keep your phone in that spot? I've been looking for one!
also, how do your coolant temps look during/after your runs?
Old Aug 3, 2016 | 03:04 AM
lovegroova's Avatar
That's a modifry dash bracket, so available in LHD as well: http://www.modifry.com/index.php?rou...&product_id=93
Coolant temps have always stayed steady at around 89F (IIRC) on track.
Downgear
Apr 24, 2013 06:53 AM
fltsfshr
May 30, 2008 02:58 PM
M.A.R.C.
South Florida
42
Oct 18, 2007 03:45 PM
dookiewhat
Jul 25, 2004 02:22 PM
