OEM Factory alarm intermittent issues
Old May 6, 2013 | 09:17 AM
oneofdadogs's Avatar
Default OEM Factory alarm intermittent issues
Anyone have intermittent issues with enabling and disabling the oem factory alarm? I have a year 2000 and i often have to press the key fob multiple times before the doors lock or unlock. Sometimes after 30 seconds i still get nothing...
I've tried different batteries, but it seems like the alarm isn't picking up the signal? is this a known issue or is there a fix?
Old May 7, 2013 | 05:21 AM
speakeasy2009's Avatar
Funny i just posted im having the same issue. i take off the battery cable and then put it back on and the alarm starts responding again. No idea whats causing this...
Old May 7, 2013 | 07:28 AM
Which battery cable are you referring to ?
It seems like the range is very poor. The key fob will eventually work, but sometimes it takes a full minute before anything happens.
Old May 7, 2013 | 03:11 PM
I remove the negative battery cable, wait 30 seconds and put it back on. As soon as I do the alarm instantly responds.. its the only way to get it working again after it dies..
Also the range is a non issue because I cant get it to work standing a foot from the car, or even leaning over into the car. Its something to do with the unit itself I guess...
Old May 7, 2013 | 11:48 PM
I've found that if i press the key fob multiple times consecutively it tends to work.
Old May 8, 2013 | 11:41 AM
BLAQ&GREYs2k's Avatar
I had a similar issue. Ended up being the battery in the fob. The security module on the car is a receiver the fob is the transmitter. Take a multimeter to the battery and ensure it is fully charged. First one i got had half a charge and simulated the problem not being fixed. All good now with a new one.
Old May 8, 2013 | 06:32 PM
Are you talking about the battery in the receiver or the key fob? Is there a battery in the receiver?
Old May 8, 2013 | 06:46 PM
i just picked up some new batteries for the key fob and i still have the same problem...
Old May 9, 2013 | 07:25 AM
yeah my battery is brand new. If the only way i can get the unit working again after it dies is to remove the battery cable, its not the key fab...
Old May 9, 2013 | 12:27 PM
Yeah if that doesnt solve it then I would head up to the dealer and see if anyone is nice enough to re-flash your security module. More than likely they will charge but if you get lucky and its a cute girl maybe you can get it done for free. It takes them like 5 mins to do. They have all the special gadgets
