ok so i'm thinking
Old Mar 5, 2005 | 05:02 PM
Bass's Avatar
Default ok so i'm thinking
John - Jim - experts what do you think
head unit = 9835
frt diamond hex's
rear s-pods diamond m3s
sub 12 inch JLw3
currently feeding everything with an alpine MRV-F450 five channel amp
and it's pretty loud BUT i was thinking that i have an older soundstream ref 414s amp that's now sitting in the basement...
so - what would i gain if i was to use the soundstream to feed the sub and use the alpine MRV-F450 to push the speakers - would there be any benifit? will it be louder?
and the next question for Jim - Jim on the spare tire rack, is there room for one more shelf??
Old Mar 5, 2005 | 05:55 PM
ricosuave's Avatar
what's the wattage to the subs on 450 vs the soundstream?
Old Mar 5, 2005 | 07:27 PM
Bass's Avatar
pretty sure the JL will take 250 to 300 - this one is their dual voice coil
the soundstream amp
pretty sure if i bridge it i can get 200 watts at 2 ohms -
50x4 @ 4ohms stereo 12volts
75x4 @ 2ohms stereo 12volts
100x4 @ 1ohm stereo 12 volts
Old Mar 5, 2005 | 07:29 PM
Bass's Avatar
soundstream link
http://www.soundstream.com/sub/owner_manual/r414s.pdf
and the JL link
http://www.jlaudio.com/subwoofers/pdfs/12W3_MAN.pdf
Thanks guys - i think i've watched John and Scott enough times to understand how to hook up the extra amp to feed the sub BUT i wanted to get your thouhts before i dive in tomorrow
Old Mar 5, 2005 | 08:15 PM
Cubs2k's Avatar
PM'd
CH5 on the Alpine is 200 watts @ 4 Ohms........
The Soundstream is 200 watts @ 2 Ohms....
SO....the JL W3...is it model D2, D4, or D6
Old Mar 5, 2005 | 11:14 PM
darkknight1999's Avatar
I knew you werent done
Old Mar 6, 2005 | 03:40 AM
PAS2KNut's Avatar
I'm guessing that it's a D2 since he currently is running it @ 4ohm's with his Alpine MRV-F450.
Given that then he would have a 4ohm load on his Soundstream and would only be driving 150 watts which would be less than his current setup. Looking at the optimum power for this sub it looks to be 250 Watts. While I'm a fan of having a dedicated sub amp (just personal preference) in this case I don't see any gain from going through all the work of getting two amps in the spare tire area. Unless you just need something to keep you busy for the day.
I will check and see. Based on the dimension of the two amps it looks like I would need 5 1/8" of clearance. If there is enough room, my only concern would be the amount of heat that the two amps would generate in such a confined space. I would think you would want some kind of cooling fans.
Old Mar 6, 2005 | 05:28 AM
Bass's Avatar
sorry i wasn't clear - it's a d2 so the sub is two ohm stable
Jim no need to check the amp rack - i figure i'll test it out and if it works just mount the sub to the left of the spare tire hump in the back
Old Mar 6, 2005 | 07:10 AM
Cubs2k's Avatar
OK....D2....the voice coils are wired in a series I assume. I wouldn't bother installing the soundstream either.
Old Mar 6, 2005 | 01:28 PM
NFRs2000NYC's Avatar
I think the Alpine is more powerful for sub use than the soundstream....(I dont have the specs on me.) Why not use the Alpine for the sub, and the soundstream for the speakers...?
Or, you can sell the Alpine, and get a big 4 channel....
But anyway, what are the specs on those two amps exactly?
One thing is for sure tho....the soundstream will run REAL hot if you squeeze all that wattage out of it. Just my .02....
see, no bashing
tukluc
Sep 30, 2010 10:18 AM
///KM
Sep 13, 2010 08:18 AM
neoarroyo
Aug 6, 2007 09:19 PM
Nhan
May 25, 2004 11:38 AM
F1 Tech
Sep 4, 2001 07:34 AM
