PAC SWI-X Installation Guide
Old Jan 6, 2002 | 02:28 AM
lucid's Avatar
Default PAC SWI-X Installation Guide
I just finished the SWI-X Installation guide.
Lucid's SWI-X Guide
It addresses the quirky MODE button on the dash as well. Drop me a line if anything is the least bit unclear.
Old Jan 11, 2002 | 03:04 AM
brock's Avatar
Excellent detailed guide!
Mike.
Old Jan 11, 2002 | 08:42 AM
DoGMaN's Avatar
I used that doc when I was doing my install, and it sure made it easier!
I love step by step
Old Jan 14, 2002 | 06:57 PM
dshea's Avatar
Lucid, this is exactly what I was looking for. Thanks for the post!
Old Jan 15, 2002 | 02:16 PM
BigRedDog's Avatar
I think the instructions are great.. but i also think it should be noted that one must first check the PAC site to check for compatability.. i found out.. after installing it found out the hard way.. that it does not have the capablility to learn the functions of the new sony's because of the IR frequency
Old Jan 15, 2002 | 02:44 PM
lucid's Avatar
You're correct I should note that. Did this deck have a wired remote input that could use S2kman's DCU?
Old Jan 15, 2002 | 04:13 PM
brock's Avatar
Does anyone have experience in beefing up the IR tx on the PAC? I am using with an alipine HU and having all sorts of difficulties in getting it to work. ie. Unit works fine when pointed directly at the HU, move it slight off centre and it stuggles to work.
Ideas? Can the IR signal be boosted?
mike.
Old Jan 15, 2002 | 04:22 PM
lucid's Avatar
PAC has an IR repeater you could try.
Old Jan 15, 2002 | 05:41 PM
BigRedDog's Avatar
[QUOTE]Originally posted by lucid
[B]
Old May 10, 2010 | 06:12 PM
gizmo1086's Avatar
does anyone have a good link to this anymore? please pm if you do. Thanks!!
