Powering lights/fan in trunk
Old Mar 18, 2005 | 07:27 PM
bwalk22's Avatar
Default Powering lights/fan in trunk
Hey guys, I am installing my sub and want to light up the trunk with some neons...my question is where do I run the power from and does anyone have any pics of the install. I also want to put a small fan to cool the amp Soundstream VGA500x4, same powering question there. thanks for you help
Old Mar 18, 2005 | 07:29 PM
LowBudgetS2K's Avatar
use a relay
Old Mar 18, 2005 | 07:40 PM
bwalk22's Avatar
not sure how to use a relay any suggestions
Old Mar 18, 2005 | 08:25 PM
Willie Gee's Avatar
find the trunk light and wire it into that circuit.
Old Mar 18, 2005 | 10:54 PM
AusS2000's Avatar
If you're installing a sub then I'm guessing there is an amp somewhere (either in trunk or in the cavity above the fuel tank) with power running to it. You could tap this supply as the lights and fan won't draw much.
You want the fan to be switch by the same trigger that turns on the amp. The lights should be switched by the boot light.
If you don't know how a relay works then stop now and get someone with basic car electronics experience to help you.
Old Mar 19, 2005 | 06:42 AM
MacGyver's Avatar
Also, you need the stuff at this site rather than neons
DangerZone9K
Apr 4, 2013 06:42 PM
ap1808
May 8, 2012 04:46 PM
CitadelBlue
Mar 1, 2012 07:44 PM
pikkashoe
Jan 20, 2005 11:09 AM
S1999+1
Nov 20, 2003 08:54 PM
