Putting in a custom sub box in the tool well. What to do with the amp?
Old May 20, 2002 | 08:17 PM
murrays2k's Avatar
Default Putting in a custom sub box in the tool well. What to do with the amp?
I'm puttingin a custom fiberglass box with 2 8'' subs. I am flushing the tool compartment with the rest of the floor and subs. The question is where would you put the amp?
Old May 21, 2002 | 01:09 PM
Pinky's Avatar
Depending on size it can go in the spare tire...........or it can get wedged inbetween the gas tank and the well for the top.
Old May 21, 2002 | 01:12 PM
Barry in Wyoming's Avatar
My installer put mine, yesterday, inside the spare tire mounted on a circular board covered with auto carpet material. You lose the bolt that holds the spare in place but it is wedged in tightly enough to suit me.
I just swapped out an Alpine MRV-T407 and put in a JL Audio 250/1 in its place. Both fit great.
It also can be mounted over the gasoline tank to the left of the spare tire.
Old May 22, 2002 | 07:29 AM
Baggs's Avatar
Has anyone had success placing the amp under either seat?
Old May 22, 2002 | 07:58 AM
mas's Avatar
mas
Not enough room there for any decent amp.
Old May 22, 2002 | 08:51 AM
Baggs's Avatar
I have a Kenwood 749S. Too big for under the seats?
Old May 22, 2002 | 11:14 AM
Shamu's Avatar
How 'bout something like this?
Old May 22, 2002 | 12:33 PM
Baggs's Avatar
Shamu, what do you have your amp mounted to? Also, what is the material made out of that you used around your amp/changer?
Old May 22, 2002 | 01:12 PM
Shamu's Avatar
The amp is connected to the actual trunk "chassis/form" using brackets: 2 up top, and 2 down low. The changer is mounted right up against the panel you see there.
The panel is made of wood (I forgot the specifc name for that composite, dense wood), with holes drilled across throughout the board to allow for as much bass to vent into the cabin. Then the entire thing is covered in grill cloth to hide the holes.
My installer also drilled holes in the convertible panel/"well" to again, allow as much bass to make it into the cabin...it also serves as a dual purpose to protect my rear window since the panel is now covered in grill-cloth too! Here's a couple pics of that panel:
Behind:
Front -- what you see when you look through the rear window and the top is up:
Hope this helps!
Old May 22, 2002 | 03:39 PM
Fast&FuriousS2k's Avatar
What I have is one 12 in the trunk well and i put 2 amps where the spare tire is
located. It fits good and keeps room in the big trunk
