Question about electical system in S2k
As promised I made these measurements a week ago but didn't have time to post them till now.
Here's what I did - I disconnected the battery ground wire and inserted a 1-foot piece of 10-gauge wire as a shunt resistor. 10-gauge is about .001 ohms per foot, so it will cause a 1 millivolt drop for each amp, which I measured with a digital voltmeter.
I then disconnected the alternator output so all the current being used would have to come out of the battery. To calibrate my shunt I measured the actual current drain of the parking lights, then measured the shunt voltage and compared the two. The readings below are corrected by that calibration factor.
[CODE]
Accessory
[CODE]
Accessory
Thanks for taking the time to measure all that Modifry!
It must have taken a lot of time and patience.
I really appreciate all your help on this matter.
Do you think we should ask to have this added to the Audio FAQ?
Mocky
Dec 26, 2002 09:31 AM
