Radio 12v power problem
Old Nov 25, 2010 | 11:29 AM
yourboysoap's Avatar
Default Radio 12v power problem
I checked everything with a voltmeter. Plugged the radio in, would turn on then off (as expected). Pressed the power button (tried with car on and off) and nothing. Broke out the voltmeter and the white/red wire at the factory harness (supposed to be the 12v source when ignition is on) is not charged. So my radio is not getting power. I have no idea where to begin to repair this broken wire. Can someone help me here?
Old Nov 25, 2010 | 02:14 PM
Figured it out. Wasnt the radio fuse but it WAS the power accessory fuse (Fuse #9, 10A). Radio power isnt on the Radio fuse circuit, its connected to the power accessory circuit (also powers the cig. lighter) according to my wiring diagram from Honda. Just in case anyone has a similar problem
Old Apr 22, 2022 | 05:19 PM
Sean Fang's Avatar
You saved my day. I had this issue coming out of winter where my stereo and 12V wasn't getting power. I even pulled all the fuses out to check and honestly didn't see this one was blown. This thread made me double check and sure enough this fuse was the problem. Took one of the spare fuses and replaced it, now I'm back in business.
Spagolli94
Aug 23, 2016 10:37 AM
Lainey
May 19, 2016 06:34 AM
gotOaks
Mar 17, 2012 10:50 AM
chillout18
Jun 19, 2009 11:04 PM
captainbk
Dec 3, 2006 07:00 AM
