Radio door won't close
Old Jun 17, 2008 | 02:58 PM
fenixv8's Avatar
Default Radio door won't close
I just installed a JVC KD-AVX44 and it sticks out too far, 3-4mm too far i believe. It hits the top of the radio door. Is there any tricks you guys kno to make it fit. i tried unscrewing the deck and pushing it further in but there is like tno room back there. =( the door closes if i remove the faceplate, but i want it to be able to close while i listen to music .
Old Jun 17, 2008 | 05:47 PM
NFRs2000NYC's Avatar
You can trim some of the inner radio door off for some headunits to get it to close, but not all. Sounds like it sticks out really far, in which case, there isn't anything you can do.
Old Jun 18, 2008 | 06:18 AM
fenixv8's Avatar
thanks for the quick response. Is there suppse to still be room behind the HU when it is installed? because i think i could get it in more if i could adjust the harness. Is there any way to access it with the HU installed?
Old Jun 18, 2008 | 07:53 AM
darkknight1999's Avatar
sent you another PM
Old Jun 18, 2008 | 03:19 PM
tampas2000's Avatar
i had this same problem with the same headunit... you have to keep messing with it... it does go in a bit more... i was able to get my radio door to close but it did hit the hu... so i cut out all of the backing of the radio door... now it fits like a charm
Old Jun 18, 2008 | 08:58 PM
fenixv8's Avatar
oic, do u have a pic of your radio door?
Old Jun 19, 2008 | 03:06 AM
tampas2000's Avatar
ill try o take some pics
Old Jun 21, 2008 | 03:13 AM
turbobunny's Avatar
Check out this link:
http://www.grandprixwhites2k.com/diyjvc.asp
He installed the NX500.... but the same idea applies to drilling holes in the bracket.... good luck!
Old Jun 23, 2008 | 08:24 AM
fenixv8's Avatar
thank you for all your help =) You guys in the electronic section are the best. better than the rest of this board
Old Jul 5, 2008 | 06:40 AM
Mocky's Avatar
looks like a pretty HU
