Rear defrost
Old Jul 23, 2005 | 02:08 PM
rm7boy's Avatar
Thumbs up Rear defrost
The rear defrost does not work. I have removed the fuse and it seems fine, and tested the fuse outlet for power and it is also fine, I am confused. It is not a very big deal the rear window is pretty much useless anyways, but if there is some kind of quick fix I would be very happy to know about it.
Thanks
Old Jul 23, 2005 | 02:29 PM
xviper's Avatar
I don't have the glass rear window but when I did the hardtop, I had to add a relay. Since the ones with rear glass can also just adapt to the hardtop rear defrost without changes at the fuse panel, I'm assuming there is already a relay. Did you check the relay? Did you check for power at the rear defroster wires? You need to locate where the interuption is.
ScoobyLai
Aug 11, 2009 06:27 PM
ronaldng0809
Nov 28, 2007 07:41 PM
SPR415
Mar 26, 2006 11:32 AM
S2k4mee
Apr 26, 2005 11:05 AM
