Rear Fill Speakers....
Old Feb 27, 2005 | 02:27 PM
SilverstoneS2k_FL's Avatar
Default Rear Fill Speakers....
I've spoken to some serious Audiophile people. It's also all over the web. They say the same thing as the articles below. I just want peoples comments because I see a lot of people in this forum putting high end speakers in the rear.
rear-fill speakers
While rear speakers might seem natural or necessary to some people, it is deemed undesirable and at best useless to those who are into good sound quality. There is nothing inherently evil about rear speakers, it's just that rear speakers often interfere too much with the ability of the front speakers to produce a believable sound stage and imaging characteristics. These effects can be minimized if care is taken to set up the rear speakers, but they are still there.
First, we discuss the "purist" view on rear speakers. Rear speakers grew out of necessity rather than the pursuit for better sound quality. A lot of cars, especially compacts and sub-compacts, have very small speaker openings in the front of the car due to space restrictions. It is rather rare to find a stock speaker location that can fit something as desirable as a 6.5 inch driver, while 4" and 4x6" speaker openings are quite popular. Small speakers are usually incapable of producing low bass (below 100Hz) at a satisfying level (say 90dB for casual listening.) Rear speaker mounting locations, especially the rear decks of sedans, offer a lot of area to mount a sizable driver, thus car manufactures rushed to mount large speakers in the rear to fill in the low bass region. This would have worked out if the stock stereos fed a low-pass filtered signal to the rear speakers so that they only produced the low bass frequencies, in which case those rear speakers would be called woofers or subwoofers. But no. Car manufactures didn't want to let all that volume go to waste so they fed the whole signal spectrum to the rear speakers. To make matters worse, the signal sent to the rear speakers is in stereo. The end result is that the center of the sound stage is somewhere to the far-right behind the driver and far-left behind the passenger. The instrument and vocal image floats all over the rear of the listener and shifts dramatically depending on the position of the listener's head. This is not how a live performance sounds.
For the reason discussed above, rear speakers of any configuration will interfere with the proper sound stage production and imaging of the front speakers. However, there are measures that can be taken to minimize the effect. The simplest thing to do is to turn down the rear speaker volume. Close your eyes, keep your head straight and adjust the front-rear fader control while you listen to a piece of music with strong central vocal content (check this with your home stereo or sit in the middle of the back seat with the rear volume turned all the way down.) First, turn the rear speaker volume all the way down, and then slowly turn it up until the vocal image starts to drift to the opposite side of the car. If you are sitting in the driver seat, listen for it to drift toward the passenger side and vice versa. This is the point where the rear speakers are still noticeable but it is not interfering too much with the proper operation of your front speakers.
There are two more things you can do but they require that you add components to your stereo system and the improvement is not as dramatic as simply turning down the rear speaker volume. Rear speakers should never be allowed to operate in full range unless you are going for the THX or Dolby Digital AC-3 theater surround sound setup. If you have a separate subwoofer, band-limit the signal going to the rear speakers to approximately between 200Hz and 3kHz. You don't need complex crossovers for this, just something like a 6dB per octave first-order high-pass filter at 300Hz and a 6dB per octave first-order low-pass filter at 2kHz. We're talking about one coil and one non-polarized electrolytic capacitor ($20 if you get the real snazzy stuff like polypropylene capacitors and low gauge air core inductors). Minimizing the high frequency content of the signal fed to the rear speakers is much more important than the low frequency content. In fact, if you do not have a dedicated subwoofer, you can do without the 300Hz high-pass filter and let the rear speakers produce the bass frequencies. But keep in mind that rear speakers should have a lower relative volume than the front so the effectiveness of the rear speaker to double as a subwoofer is severely limited.
To wring out the last bit of negative side effects, the rear speakers should be in mono. This can be done only if you have an external amplifier. In other words, this is impossible with a stock stereo system. The simplest way to do this is if the amplifier has a stereo/mono switch built-in, or to use an amp that is bridgeable. Then just put the two speakers in series and bridge them across the amplifier. If the amp is not bridgeable, you will have to find a crossover or some other signal processor that has a mono output. However, most of the crossovers and signal processors only have mono output for subwoofers (music below 200Hz) and thus are not suitable for this purpose. So the simplest way to do this is to get an inexpensive bridgeable amplifier.
If you do decide to get rear speakers, you would have to decide which type or brand of speakers to get. After reading what's written above, if you think all this rear speaker negative side effect crap is hog wash, just pick out your rear speakers. But if you are now a faithful believer in low-volume band-limited mono rear speakers, read the next paragraph
Your cheapest and simplest solution is not to have ANY rear speakers. The next cheapest solution is to keep your stock rear speakers. The reasoning behind this is that most stock speakers are quite OK in the 200Hz to 3kHz region. It is in the bass and high frequency region where they run into trouble. Besides, you are going to be running it low-volume, band-limited and in mono, so the difference between a pair of stock rear speakers and say a $250 pair of high quality mid-bass drivers is not going to be all that noticeable. But again, it is important that you keep it low-volume, band-limited and in mono. If you have a lot of money (send me some) and really want a fancy spare-no-expense type of system, then go ahead and find a good solid pair of mid-bass speakers. DO NOT, I repeat DO NOT, I'll say it again DO NOT buy co-axials or component speakers to use as rear fill since you are going to be wasting a lot of money on the useless tweeter and crossovers. You might be rich but you don't have to be stupid. A $200 set of components or co-axials might be just so-so but a pair of $200 mid-bass drivers is going to be killer. A lot of companies make really good mid-bass drivers. Look into Kicker, JL, Boston Acoustics, MB Quart, Audax, or Morel just to mention a few. There are also a few high dollar brands such as Dynaudio, USD Audio, Image Dynamics and Focal. This is not an inclusive list because there are a LOT of good mid-bass drivers out there.
AND NEXT ARTICLE
Rear Fill Speaker Installation
The real secret to rear speakers is design. Placement and output level are critical The idea is to add
Old Feb 27, 2005 | 03:44 PM
NFRs2000NYC's Avatar
I buy it. Rears are meant as fillers, not primaries.
Old Feb 28, 2005 | 06:49 AM
PJK3's Avatar
i've been saying almost the same things for quite a while actually....
i'm not so gung ho about band limiting the upper frequencies of rear speakers, but then i think i set rear volume levels lower than many people would.
all in all, it seems to be good advice all around.
rear speakers represent fill and/or ambience - not a primary sound source.
Old Feb 28, 2005 | 09:51 AM
marks2002's Avatar
I agree that it's not necessary to spend a lot on rear speakers because they only add rear fill.
However it all really boils down to a matter of personal taste. A couple of my friends subscribe to the "no rears at all, high quality fronts, lots of power, and a powerfull sub" school of thought. Their systems sound great, BUT I prefer the sound of my lesser quality (but still decent) system with rear speakers. As good as their systems sound, to me they are a little lacking without rears. They prefer the sound without rears to mine with rears.
Best thing to do is listen to a couple different systems before deciding.
What sounds "perfect" to an audiophile won't necessarily to the rest of us who like some rear fill.
Old Feb 28, 2005 | 09:55 AM
marks2002's Avatar
I agree 100%.
Old Feb 28, 2005 | 10:09 AM
PJK3's Avatar
personally, i'm not running rears at this time. i DO like the sound of 2 up front high quality speakers dominating my sound.
however, i also enjoy a rear fill. properly setup and managed, it can be made to sound very natural and enjoyable. the only thing is that w/ the S, there's no easy or inexpensive way to get appropriate rear fill. i don't like Lucid's setup, and for the benefits i'd gain, the S-pods represent more investment money than i'm willing to part with right now.
it's a bang for buck thing with me right now... i've heard (and helped tune) some S-pods in the past... they can be made to sound awesome. just don't expect to run them anywhere near the power you have in the fronts.
*edit*
btw -- perhaps this thread should be cross referenced in the FAQ?
Old Mar 1, 2005 | 09:13 AM
marks2002's Avatar
I'm curious how you tuned the system/systems you spoke of with S-Pods. I fade towards the fronts 6-7 steps on an Alpine deck. Was your tuning more extensive than that?
Old Mar 1, 2005 | 04:15 PM
TR-S2K's Avatar
As always, you are right. I set my fader such that the rear sound pressure level is much lower than the front.
Old Mar 1, 2005 | 04:20 PM
Willie Gee's Avatar
brainy smurf always says you listen to the speakers up front, and the rears are for fill only.
Old Mar 1, 2005 | 05:44 PM
flitcroft's Avatar
I've heard highest-end systems in the S2000 both ways, but like Phil I don't see the dollar/value being quite there if you've already shelled out for an audiophile system. I actually prefer the sound of rear fill in this car (although I haven't heard good aftermarket speaker mounts that aim the woofers correctly at your ears), but in my system I'd want to add MB Quart QSD components @ $500+, then S-PODS, then replace my two channel amp with a four channel amp. That's at least $1,000. Maybe I could have planned better but at the competition-end of the spectrum it seems too expensive.
With enough volume I can move the soundstage up to the right height level, and my bass takes care of the rest of the fill duties. With lower volumes the benefit of rear fill would be very nice.
