remote start
Old May 30, 2011 | 10:54 AM
boiii4's Avatar
Default remote start
I need help bypassing the clutch to remote start. i know the wire is blue but where does it located at? Can somebody help me? thanks
Old May 30, 2011 | 02:54 PM
NFR_AP2's Avatar
probably at the clutch switch? you can always just unplug it if you want although i wouldnt recommend it
Old May 31, 2011 | 06:11 AM
snipe99's Avatar
there are 2 plugs on the clutch pedal unplug 1 of them to see which is needed to start the car. ( i forget which one) Once you realize which one it is you can basically ground it out. meaning, just connect the 2 wires in the plug to each other
Old Jun 1, 2011 | 07:14 AM
irv_usc's Avatar
This is pretty dangerous if you somehow leave your car in gear and then try to remote start it.
Old Jun 1, 2011 | 11:49 AM
RobHimself's Avatar
If you jump the higher of the two plugs wiring together you will bypass the clutch. You can also run your nuetral safety wire to it or the e brake. There are mutiple other safe ways to do a remote start in your S safely. I do 12 volt for a living so feel free to pm me if you have any questions. I just put a rem start/alarm in my new ap1 a couple days ago.
Old Jun 2, 2011 | 04:32 PM
boiii4's Avatar
thanks. it the light blue wire that i tap it and ground it! is that safe?
Old Jun 5, 2011 | 06:05 PM
RobHimself's Avatar
I just tapped it into the other wire at the switch. But to answer your question, no it isnt safe. They're are plenty of safe ways however to install a remote start in your car. What brand remote start are you using? I personally deal with DEI product on a daily basis and find their manual transmission mode failsafe.
Old Jun 6, 2011 | 05:29 AM
snipe99's Avatar
that is correct just grounding the plugs is not safe at all. I too personally work with dei product on a daily basis and have found that using the standard transmission mode on the dei is your best bet no matter how annoying it may be.
jwzimm
Apr 9, 2021 05:44 AM
AR-9
Jul 13, 2010 01:29 PM
sbrodacz
May 3, 2008 09:33 AM
f00dstamps
Feb 8, 2005 08:45 AM
