Remote Start COMPLETE
Old Oct 19, 2007 | 11:26 AM
Stealth_SUX_'s Avatar
Default Remote Start COMPLETE
Finally it works
For those of you that are trying to do this..
Direct Techs wiring diagrams shows two ignition wires, but our car actually has 3 ignition wires. And most alarms only have two ignition outputs so you must use a relay if you dont have three ignition outputs on your alarm.
Old Oct 19, 2007 | 11:39 AM
Doug1627's Avatar
Nice. I was considering one of these with winter coming up.
When I park the vehicle does it need to remain in neutral or can I park it in gear?
Old Oct 19, 2007 | 11:45 AM
cliffdogg2k's Avatar
Must be in Neutral...Most have some type of process you go through before you get out, if you want to use Remote Start the next time you Start.
Old Oct 19, 2007 | 11:53 AM
Doug1627's Avatar
Does that process not allow the starter to work if the vehicle is in gear? I want one but I fear that I will try to start it while parked in first gear.
Old Oct 19, 2007 | 05:54 PM
ss04's Avatar
Care to elaborate a bit? I'm just finishing a Compustar Pro install with an Honda SL3 Bypass kit but I haven't touched the ignition portion of the car yet...
What 3 wires should I be working for (colors)?
Also, what type of relay wiring? Any help would be great thanks in advance...
Cam
Old Oct 20, 2007 | 10:44 AM
Cam
I followed all the wire colors direct techs gave me, except since they didn't have the 3rd ignition wire I had to probe and find that.. I dont remember which color it is, but I will be going back in to clean up the install so I will get you that information soon. I work today and tomorrow so I will try to get it to you asap..
Old Oct 20, 2007 | 11:04 AM
ss04's Avatar
Thanks Will save me some time and frustration
Old Oct 23, 2007 | 06:53 AM
modifry's Avatar
Honorary Member
The third "ignition" circuit is not required - it's just for the radio and accessory socket.
There are 4 ignition wires that need to be powered but it's only 2 circuits. One circuit is divided up into 3 separate wires so it can feed different fuses, but inside the ignition switch they are all connected to the same place. You need to power blk/red with one of your remote start's ignition relays and use the other relay output to power one of these: blk/yel, blk/yel, org. Powering one of these wires will put power on all 3 of them.
Old Oct 23, 2007 | 06:58 AM
modifry's Avatar
Honorary Member
[QUOTE=Doug1627,Oct 19 2007, 02:53 PM]Does that process not allow the starter to work if the vehicle is in gear?
Old Oct 23, 2007 | 07:35 AM
Doug1627's Avatar
Originally Posted by modifry,Oct 23 2007, 09:58 AM
The remote start systems usually have a "shutdown process" you must go through to establish that the car is in neutral (like it must see the clutch pedal up and the engine running).
Personally, I don't trust those methods as it's too easy to put the car in gear after you've done the correct "setup". You might consider adding a neutral switch or brake switch. I added both, along with a sensor to detect if the car moves. Details here
Thanks for the link!
