removing gauge cluster
Old Aug 9, 2005 | 10:27 AM
Arbeeezy's Avatar
Default removing gauge cluster
Do you have to remove the steering wheel in order to remove the gauge cluster? It says so in the Helms but I don't see why. Let me know if anyone has done this. Thanks!
Old Aug 9, 2005 | 11:39 AM
Ishift@9.1's Avatar
Banned
It looks to me like you'll definitely have to at least drop the steering column.
I was trying to take the bezel piece around the gauge cluster and I had to drop the column to even get it to the point where it was remotely able to come out.
I gave up though...it was late at night.
Old Aug 9, 2005 | 12:49 PM
Arbeeezy's Avatar
how did you drop the steering column?
Old Aug 9, 2005 | 01:57 PM
r_duff's Avatar
3 screws to remove the lower column cover. 4 12 mm nuts hold the column up. the 2 closest to the firewall can be loosened; dont remove them completely. The 2 closest to the steering wheel need to be removeded completely.
on the underside of the cluster hood, there are 2 pop out caps that hide 2 screws. Unscrew those next. The rest of the dash is held in by little clips, just start poping it out with you fingernails, or a flathead screwdriver (use a cloth or tape to protect from scratching). You can then tug and pull the bezel out, while you unplug the start button, audio controls, cruise switch, defroster switch (if so equipped), and HVAC controls.
Once that whole unit is out, there are 2black screws that hold in the cluster on each side. remove, and pull out the dash. There a 4 plug behind the actual cluster.
There is VERY little slack in the wiring harness. I found it's easiest to have a small screwdriver handy to push the 'lock' of each connector as you pull. Good luck!
Old Aug 9, 2005 | 01:59 PM
r_duff's Avatar
PS: its always safest to unplug ur batttery first (recommended). I never do, but if you dont, atleast make sure the top is UP, or you might get a little shower
speed bullet
Feb 21, 2011 05:46 PM
MY04NFRS2000
Apr 1, 2010 10:08 AM
J_STATUS
Apr 13, 2008 07:09 PM
Terrance914
32
May 9, 2005 08:44 AM
jdmdohcpower
Oct 24, 2004 05:07 PM
