Roll hoop replacements
Old Aug 8, 2007 | 08:41 PM
GTS Jeff's Avatar
Default Roll hoop replacements
I'm talking about the 06/07 roll hoop speakers. I found these and they seem like they'd work well as an upgrade. If they are wired in series to an aftermarket deck, then they should see about 11 WRMS (assuming the standard deck puts out 22WRMS per channel.) But would they fit?
http://www.cdtaudio.com/pdf/HD-2.pdf
The HD-2 is a unique 2" mid tweeter (more dispersion at the highest frequencies) than most 25mm dome tweeters. A 1kHz (6db) or 500Hz (12 db) crossover is recommended.
They go for $100 a pair..
Old Aug 9, 2007 | 01:25 PM
GTS Jeff's Avatar
No one cares about roll hoop speakers?
Old Aug 9, 2007 | 02:01 PM
philbert's Avatar
I've included links to a couple previous threads discussing possible replacements for the rollhoop speakers. Unfortunately, I don't believe anyone has found a successful solution yet.
older, longer thread:
https://www.s2ki.com/forums/index.php?showt...l+hoop+speakers
newer, links back to above:
https://www.s2ki.com/forums/index.ph...pic=483393&hl=
The first issue with the CDTs you mention is the 1.26" mounting depth. Based on this picture of the rollhoop speaker area, there is only about .75" of depth available. I'm thinking that with the outward curving cover piece, a spacer could be added to a slightly deeper speaker that would still work under the factory cover, but i don't think there's a full 1/2 inch to work with...
The outer diameter of 2.65" also looks to be too much width for the space:
Old Aug 9, 2007 | 02:12 PM
philbert's Avatar
But in fairness, after replacing my front speakers with a/d/s components powered by an external amplifier, powering the rollhoop speakers with the rear channels of the Alpine HU, and adjusting the fader to have the rollhoop speakers add just enough fill, I'm not too displeased with them. I am much happier with speakers trying to reproduce some midrange as opposed to component speaker tweeters firing only the upper octaves straight into my ears.
Old Aug 9, 2007 | 04:51 PM
SheDrivesIt's Avatar
Looks like they would be too deep.
Old Aug 9, 2007 | 08:34 PM
GTS Jeff's Avatar
Damn! Back to the drawing board...
I guess I could look for the biggest silk tweeter out there...
Old Aug 10, 2007 | 06:17 AM
itsmylittlebrothersbike's Avatar
rear fill done right makes a big differrence.
Old Aug 10, 2007 | 07:43 AM
philbert's Avatar
As I mentioned, even though the factory rollhoop speaker may not be the best quality, the fact that it covers some midrange makes it much more tolerable (IMO) than just having a tweeter right next to your ears.
I was/am considering the Tang Bang driver below, which a forum member was going to look into testing out before he ran into some other issues. I may have to give it a try... 4 of them qualifies for the "volume discount" of less than $11 each. They are spec'd to extend down to 400Hz, and hopefully with a small spacer, would have adequate mounting depth.
Tang Band W1-1070SE 1" Full Range Driver
Old Aug 10, 2007 | 10:52 AM
JackS's Avatar
Im not saying that this is absolute but IMO the rear speakers are mainly for effect. Spend the extra $100 on better door or components and leave the stock rears in place.
Sound improvment will come mainly from the front primarys and any improvement in the rear may go unnoted.
If several people on this forum dissagree, then I might be wrong.
Bottom line- Great attention to the front and only minor (if any) to the rear.
Old Aug 10, 2007 | 12:20 PM
GTS Jeff's Avatar
Yeesh, those seem as low quality as the factory ones...I think I'll wait for some feedback on those before I go for it.
