Screen in dash mounting help
Old Nov 28, 2005 | 03:33 PM
ideugene's Avatar
Default Screen in dash mounting help
When mounting a screen, or more specifically a GaugeTech EMS display (www.gauge-tech.com) into the dash, what's the best way to keep it in place? I'd like it to be removable just in case I need to change wires or something, yet secure enough so that it's not going to fall out when I hit a bump.
How is the JDM bezel held in place? From what I can tell, it looks similar to the way the radio door is held with the mounting tabs being pushed into slotted holes. I was thinking I can get a JDM bezel or a new radio door and modify it to accomodate the size and shape of the display. Any suggestions?
Old Nov 29, 2005 | 06:39 PM
ideugene's Avatar
Bump for some help
Old Nov 30, 2005 | 08:31 AM
mikes2k's Avatar
Mine is mounted with a long thru-bolt design. The bolt is embedded in the back of the bezel..at the other end is a washer for grab purposes. So it can be tightened and loosened. I wish I had a pic for you to explain it better.
Old Nov 30, 2005 | 10:54 AM
ideugene's Avatar
^ Thanks for the reply.
So basically its bolted into place? If so, how the hell do you get back there to bolt it up?
Old Nov 30, 2005 | 11:07 AM
mikes2k's Avatar
Yes, through the airbag cutout in the dash. The airbag unit lifts up with a few screws ...move it over a bit and reach in and tighten/loosen. Retighten the airbag unit and done!
Old Nov 30, 2005 | 11:17 AM
ideugene's Avatar
I remember seeing your set-up years ago, I think it was the first one ever.
The bolts embeded in the outer-most edge of the bezel correct? Which go straight into the dash and bolt on using a washer/nut? Thanks for the help man!
Old Nov 30, 2005 | 12:31 PM
mikes2k's Avatar
Thanks! Yeah I think I was the S2k dash guinea pig Yes, a big washer/nut grabs onto something back there and that is how it tightens. Good luck!
Old Nov 30, 2005 | 01:45 PM
ideugene's Avatar
Not really sure I understand what it grabs on to but thanks! We'll see how this thing turns out!
Old Nov 30, 2005 | 03:00 PM
Matts2k's Avatar
Where can you get a jdm bezel from? Ive always been interested in doing this.
Old Nov 30, 2005 | 05:30 PM
ideugene's Avatar
I'm getting it from an import company... www.japanparts.com
They are REAL slow in returning e-mails but I don't know anyone else that can do it. I did have a Japanese friend in high school... hmmm maybe its time to look her up.
