Setting crossover point, at headunit or poweramp, are they the same?
Old Jul 21, 2002 | 07:02 AM
scooby2's Avatar
Default Setting crossover point, at headunit or poweramp, are they the same?
Assuming that the headunit and the poweramp crossover slope is the same (12 db/octave), is there an advantage to using either one for the crossover point? Is one setup more efficient than the other?
Let's say I want a high-pass frequency of 75 Hz, I set the headunit crossover point at 75, does it matter if the poweramp is set for full range or maybe at a crossover point of 50 Hz? Do I gain anything by not having the poweramp "play" full range even though the low frequency signals aren't reaching the amp?
Old Jul 21, 2002 | 10:10 PM
pcloadletter's Avatar
In general, the amp will have cleaner crossovers. Try to do all your settings at the amp. But if they have the same specs, there shouldn't be a difference.
Stoatmaster
Feb 18, 2014 02:15 PM
S2000_916
Oct 19, 2011 08:38 AM
s2Keanenk
Feb 6, 2008 01:58 PM
PJK3
Jan 14, 2007 06:50 PM
2000celicaspeed
Jul 16, 2004 07:39 AM
