Soldering vs Crimping
Get a soldering iron! You only need a cheap one nothing fancy - Target and walmarts sells them for like $10
Use Rosin Core Solder though - its for electronics
Remember heat the metal not the solder
Crimp is fine. In fact, more bad connections come from bad solder jobs that bad crimp jobs. In a past work career I was a journeyman electrician and a good crimp connection is always to be preferred to a soldered one. Which isn't to say that crimp connections can't be bad -- they can. Nor that solder connections can't be good -- they are when done correctly. But it's very easy to create a "cold" solder joint if you don't know what you're doing, and a cold joint will fail. The only question is when. And one of the worst things for a cold joint is vibration. Hmmm. Think we have any?
If your going to crimp use a CRIMP CAP. This way you twist the wires together making a tight connection then crimping on top of that. This way its almost idiot proof!
Soldering is fine. Thought I don't like to do it alone......If its 2 wires together I like that plastic cover over the top. If your tapping into a wire then solder is a must and separating and making a hole in the wire wrapping then soldering.
Better even than tape -- heat shrinkable tubing. Even really good tape has a limited temperature range. It's either really good even when frozen, or really good even when hot. But not really both. The best general purpose is Scotch 33+. But in a hot interior, it might not do too well, over time.
I have a question for the crimp gurus among us. I know that a thick high % tin plating is preferred on the crimping connector for two reasons. You want a "gas-tight" crimp and tin oxides are conductive. However, it seems to me that also means you'd get more reliable crimps if you pre-tin the wire also. Bare copper oxidizes damn quick. Am I missing something?
Then I just slide the heat-shrink over the joint and heat it up. Simple fast and makes for very good connections. Just remember to slide the heat-shrink on the wire first if you allready have a connection on the other end
Ole
White/Red;
