stereo power questions
by NSXS:
Correcto-mundo. In most cases (I've seen) with good-quality car amps you'll only get about 3 times the output power because of increased losses through wiring (internal and external to the amp) and some power supply sag when it tries to supply the extra current. You'll usually get more power by bridging at 4 ohms than by straight amp with 2 ohms, unless you're going to use two drivers with the straight setup. I always had room for the amps but not the extra drivers, so I preferred bridged.
Years (and I mean years ) ago, (before bridged amps were around) I used an op-amp inverter to invert one input of a stereo amp to achieve the same effect. Should have marketed that idea. Oh well.
MacGyver: thanks for the correction, we're all subject to the occasional brain fart, glad to see the edumacated among us aren't exempt.
Usually when you bridge anamp you get 4 times the power of a single channel (you actually get twice the voltage output, and power is related to the square of the voltage).
m1sterlaw
Oct 13, 2011 09:18 AM
