Sub install - Impedance
Old Mar 7, 2012 | 06:41 AM
BooGTS's Avatar
Default Sub install - Impedance
So I have this amp already:
http://www.techronics.com/caraudio_7...Amplifier.html
And it has
4 ohms: 150 watts x 2 chan.
Bridged, 3 ohms: 300 watts x 1 chan.
I want to run a 10" sub, this seems to fit my price range and seems very good for the $:
http://www.amazon.com/Infinity-Refer...1134509&sr=1-1
Now, with that amp, Do I want to run a DVC or SVC? Neither seems to get me to my goal of 3ohms. From what little I know, I want to match the amp and sub impedance. I will likely be running it in a rrq box like this: http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123 Thanks!
Old Mar 7, 2012 | 07:50 AM
2big4aS2000's Avatar
that amp will produce 300 watts - with impedence (ohms) from 1.5 to 4)
I would do a DVC - wired parrel, 2 ohm load.
Old Mar 7, 2012 | 06:00 PM
BooGTS's Avatar
alrighty, thats what ill do then
Old Mar 7, 2012 | 06:09 PM
oth's Avatar
oth
While I hate to contradict 2big4 who certainly knows his stuff, it looks like in
bridged mode that amp produces 300 watts from 3-8 ohms, rather than the 1.5-4 ohm
rating unbridged (150w per channel x2) mode.
Looks like that DVC sub can be wired 2 ohms (parallel) or 8 ohms (series). Parallel
will bring the impedance below JL's rating, but in series at 8-ohm you'll still get
the 300 watts. With most amps you'll get the most power out of them at the lowest
rated impedance, but those JLs have a regulated power supply which produces the same
power across their whole rated impedance range.
Old Mar 8, 2012 | 07:01 AM
you are correct, if it wont do the 1.5 then do SVC (4ohm)
Old Mar 8, 2012 | 05:02 PM
BooGTS's Avatar
So I want to go with the SVC or the DVC in series? Just want to confirm. Appreciate the responses!
Old Mar 9, 2012 | 07:17 AM
oth's Avatar
oth
If you will always be running with that amp, I believe it doesn't matter -
the amp produces 300 watts for any impedance from 3-8 ohms.
4 ohms (SVC in this case) is the most versatile, as virtually any amp is
4-ohm stable, even when bridged. But if you went with a dedicated mono
sub amp, most of which are 2-ohm stable (some multichannel amps are 2-ohm
stable when bridged also) and don't use a regulated power supply like the JL,
you'll likely get more power at 2-ohms (DVC in parallel).
Old Mar 9, 2012 | 08:00 AM
BooGTS's Avatar
Sounds like I'll just get the DVC and wire it in series, for the less than $10 it will cost and be better for the future (I use subs very gently). This thread has been great, I had no idea the JL's were regulated (it was in a car I bought, then I returned the car to stock when I sold it, so I didn't do the research I would normally do when purchasing).
murderedrsx
Sep 24, 2012 05:43 AM
User 71524
Jun 14, 2007 11:11 AM
GunMeTaLCLSPiG
Mar 24, 2006 03:46 PM
lude2S
Jul 4, 2005 02:51 PM
mcomer
Apr 28, 2004 05:54 AM
