Which sub should i get...
Old May 23, 2005 | 10:47 AM
nazaracing's Avatar
Default Which sub should i get...
Hi, i'm about to build a sub box in the trunk that will fit into the area where the tool kit was originally.
I got the diagram from one of the posts here on the s2ki forum and it appears that it will give me about .9 cu of volume.
I was wondering what sub i should/could put in so that it sounds nice.
I don't want to spend millions for this sub, just something around 200-300$
I was looking at the INFINITY KAPPA PERFECT 12.1D 12" SUBWOOFER which seems popular with the s2000 owners....
The only thing is that i read that it needs 1.0 cu and i will get only about .9.. will that mess things up for me?
I'm building the box out of MDF.
Any help would greatly be appreciated. (i will be using the sub with my alpine 9855 and an amp which i have yet to purchase... no idea what i should get).
Dave
Old May 23, 2005 | 02:18 PM
dbzerk's Avatar
Hey.. i installed my Xtant sub in the same spot and i got 1.27 cubic feet by making the box out of fiberglass..
heres my link..
https://www.s2ki.com/forums/index.php?showtopic=289014
Pm me me if you need help..
Old May 24, 2005 | 06:45 AM
nazaracing's Avatar
WOW that is amazing.. i would love to do that but i have never worked with fiberglass and i'm a little scared. I would give it a try but i'm not too sure where to begin. If you could tell me a little about it, it would be great.
Thanks for the help,
Dave
Old May 24, 2005 | 08:28 AM
PJK3's Avatar
the JL 10W6 and 12W6 will both work just fine in .9 cu ft..
and no, if you want to put that Infinity into .9 cu ft? and it recommends 1 cu ft? it probably won't affect the sound much at all... i wouldn't go a whole lot smaller, but .1 cu ft is not a lot of space. imagine 4 rubik's cubes (normal size) and you've got right at or just a little more than .1 cu ft total.
Old May 25, 2005 | 03:50 AM
dbzerk's Avatar
If you managed to get .9.. thats fine!.. it will have more punch then bottom end bass..
As for the fiberglassing.. check out marine stores or body kit places and look for something called "fiber glass repair kit' this will come with instruction on the basics of fiberglassing... my box was made from a single large kit!
Its pretty easy once you know what you are doing.. pm me if you need more advice champ!
Old May 25, 2005 | 08:29 AM
nazaracing's Avatar
THanks a lot guys... i will get the INFINITY ones.... i hope that it will sound good.
Does the JL work well with .8 or .9 enclosures??
I really want something that sounds amazing...
So which do i get? Or should i get an alphasonik?
Please help me out guys, i have to buy the sub this week.
Old May 25, 2005 | 01:22 PM
Gavan's Avatar
Image Dynamics
No No No, get this one!!!
and I am not kidding, I have a couple.
Fits your price range
fits in a really small box
great sound quality
good response
really loud with a good amp
haven't blown one yet
has anybody fried one of these yet? I'm curious.
I've fried just about every sub I've ever had.
Old May 25, 2005 | 02:27 PM
nazaracing's Avatar
Hey thanks for the advice, i looked and it and it looks good... i'm not really sure how to chose the right sub... they all look the same to me. I wouldn't know how to chose one based on specs .. the only way i could is if i would hear them.
Um... is this one good http://www.cardomain.com/item/IDSIDQ12D2V2
It's the same ones you were telling me about but it's the 12"... i really want a 12".
Does anyone else have any experience with these subs??
Dave
Old May 25, 2005 | 03:01 PM
Gavan's Avatar
I have had mine for about 8 years and never had a problem.
The one you chose is a dual 2 ohm, so it would be running a 1ohm load to an amp if run parallel wired, you may want the dual 4ohm so as to run at 2ohm
this will depend on what amp you choose/own
you will want to run as close to if not over the nominal wattage, like 350-500
this will mean you will not be at full output on the amp when you are at 3/4 volume on the head unit, any thing over 10% distortion will blow speakers, leave a good amount of dynamic headroom to allow peaks
more wattage is your friend, less will destroy
donkeykong
Mar 8, 2009 12:29 PM
plutonium239
Aug 20, 2007 01:47 PM
DDuds2k
Aug 6, 2007 08:52 PM
GTI_JAY
Jan 29, 2007 10:14 AM
RBR
May 2, 2006 04:42 PM
