Subwoofer rattling
Old Sep 10, 2009 | 04:20 AM
s2kZac's Avatar
Default Subwoofer rattling
hey so i installed my l7 from my last car and when the top is up it rattles really bad i was wondering what i should do to stop it and get cleaner bass.
Old Sep 10, 2009 | 07:00 AM
DFWs2k's Avatar
the best/easiest ways are to remove the rear tray completely, or vent it
another way that will take a lot of time and you might get lucky enough to have it actually help, is to stuff foam/matches/something around the "edges" of the rear tray, the middle will still probably rattle though (i could never get this method to reduce rattles)
Old Sep 10, 2009 | 10:37 AM
kdoggx2o00's Avatar
yeah just remove the convertible tray..i did mine and my l7 sounds so much better after..its a night and day difference
Old Sep 10, 2009 | 11:05 AM
DFWs2k's Avatar
yea, you can feel the bass a lot more as it doesn't have to mess with all that plastic anymore
Old Sep 11, 2009 | 03:40 AM
s2kZac's Avatar
how do you remove tray
Old Sep 11, 2009 | 04:56 AM
GregFarz78's Avatar
This is good to know before I install my sub, is the tray hard to remove or do I have to remove the entire top to get it out?
Old Sep 11, 2009 | 07:16 AM
DFWs2k's Avatar
there are little clip things holding it in, you have to push in the center of the clip (with a pen or something), and then you can pull the clips out, takes about 10-15 minutes ? less than 10 clips?
very easy
Old Sep 11, 2009 | 08:46 AM
camuman's Avatar
if you remove the vert tray, does it in anyway compromise dropping the vert top?
Old Sep 11, 2009 | 09:04 AM
DFWs2k's Avatar
mine's been removed for 2+ years, i have a pretty big amp mounted in place of the spare tire, and no damage to glass rear window (i was concerned about this at first)
Old Sep 11, 2009 | 09:36 AM
Kwando's Avatar
i cut 2.5" holes in my rear tray and installed it back in place with a muz mat...no rattling, good bass, still protects my plastic window
