Sun Auto Hyper Ground System
Old Jan 20, 2007 | 01:25 PM
S2kMr's Avatar
Thumbs up Sun Auto Hyper Ground System
Any members here have Sun Auto Hyper Ground system? I just purchase a used set of Hyper Ground system from another member here on s2ki, and it only came with 4 wires and no battery terminal clamp. The seller told me he bought it 2 yrs ago.
http://www.sunautomobile.com/products_hyperground.htm
on their website listed 5 wires and battery clamp. My question is do they have older version Hyper system that comes only 4 wires? and no battery clamp? I don't want to jump on the seller until I find out all the facts. Thanks for your time.
Ben
Old Jan 20, 2007 | 04:04 PM
gomarlins3's Avatar
Exactly why did you buy this item?
Old Jan 20, 2007 | 05:01 PM
S2kMr's Avatar
From Sun Auto
This system provides direct ground path from battery negative to body, chassis, and engine components to give extreme improvement on electrical circulation. In addition "Hyper Ground System" cables have 10 times less impedance than factory ground systems which provides immaculate conduction to prevent electrical power loss.The higher resistance of factory grounds, effect the ignition system and obstructs the primary potential.
The "Hyper Ground System" uses thick gauge 99.99% pure copper, and connects directly from the cylinder head and other points under the hood to the battery, to provide an ultra low resistance connection.This will increase the primary potential of regular cars to ignition tuned vehicles.
How well it work? I can only tell you after the installation.
Ben
Old Jan 20, 2007 | 05:08 PM
Shadow_S2K's Avatar
Former Sponsor
I believe he asked you the question because it has been said to do nothing, and is a waste of money. People say a ground system would only work on old cars with bad grounds and not on the S2000 which has good grounds already.
You prolly will notice nothing different at all...
Old Jan 20, 2007 | 08:40 PM
WashabiS2K's Avatar
i would only "buy" a grounding system to snazzy up my engine bay.. unless someone can make me a grounding set with transparent red wires.
Old Jan 20, 2007 | 09:07 PM
Ruprecht's Avatar
dang, never heard of that one.
5hp for better electric flow??? I could maybe see it for an electric golf cart, where the motor is electric...maybe.
Old Jan 20, 2007 | 09:16 PM
gomarlins3's Avatar
Now that's funny.
Old Jan 21, 2007 | 10:12 AM
kane.s2k's Avatar
It doesn't matter how many wires there are or aren't because it doesn't do anything anyways.
S2kMr's Avatar
Back on topic, send an email to sun auto, will find out this week. And ppl that OWN this system are welcome with comments because it's based on experience with real facts.
Old Jan 22, 2007 | 06:47 PM
piedrafria's Avatar
5 wires and a battery post. I don't believe I gained any horsepower but I do feel it evened out my throtle resonse. The response was just "smoother". Anyway, every magazine that has tested these wires has had a positive response but they all said they tried numerous wire connection points with dyno tests in between to find the right set up.
